Old 02-18-2013, 09:58 AM   #11
daydreaming about camping
jeeplj8's Avatar
In addition to the information already posted, note that 4WD is typically limited to speeds under 55 mph. your manual will tell you it should ONLY be used on loose slippery surfaces such as snow/ice, gravel, sand etc. It should NOT be used on pavement unless one of those conditions exists.
At 28 ft, I suggest you look at a built in anti-sway device such as Equalizer. A friction bar is probably not sufficient.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 02-18-2013, 10:24 AM   #12
caper's Avatar
They do recommend using 2 friction sway control units if your trailer is 28' or longer. I had the husky round bar sway and like you did not want to put the extra in purchasing a second unit. I have 2 sway control units on my set up. Have traveled across Canada several times pulling the 34' TT. The only time I had white knuckles was when we hit a storm with cross winds pushing 40+ miles per hour. The winds were so strong that it pushed fully loaded transport trucks off the road.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-18-2013, 10:27 AM   #13
jeeplj8's Avatar
In my opinion the friction bar style of anti-sway is inefficient, balky and designed to fail. Two would be twice as bad.
However, each of us is different. I would get a WDH with integrated anti-sway.
f250
