Old 02-17-2013, 02:54 PM   #1
A few F250 questions
We just bought ourselves a 2009 F250 with long box, supercab and V10 engine. It's replacing our old 2000 F150 that has a V6 in it. Our old truck for the most part hasn't been too bad for power, but it does struggle on steeper and longer climbs, plus it tends to sway more than I'd like. The F250 is going to be a world of difference. It just seems physically so much bigger all around. We're going to be upgrading to 28 foot or so ultra-lite trailer weighing about 6,000 lbs.
We don't pick it up until this coming week and in the meantime I have a few questions.
1. It has a limited slip differential (4.3). Are these of any benefit for towing a TT?
2. Has the 2WD/4WD switches on the dash which is nice. Will it help much to tow in 4WD mode?
3. It has the "towing package". We are going to use the Prodigy P3 b/c we have now. Is it easy to connect it yourself? Does Ford leave 4 accessible wires coiled up under the dash or what?
4. Am wondering if a friction type sway control is going to be a necessity, highly recommended or just a nice accessory to have. Also not sure if we'd need a single one or one on each side? The only thing I'm not if I like about these is the effect on turning radius. We currently have the round bar type WDH and don't want to have to rush out and spend more $$ on a combo type WDH/sway control.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 02-17-2013, 03:11 PM   #2
QCCowboy's Avatar
I had a 20120 F250 with the V10 and 4.10 rear end. Don't know if I can help at all with the first question as we had different gearing, but I might be able to help with the other questions and I am sure that others will add their thoughts as well.
You should have no reason, nor would you want to tow in 4WD unless you get stuck or for some reason need the additional traction (I have never used 4WD when towing).
Yes, the adapter that you will need to connect into is hidden under the dash. They actually make an adapter kit that will tie right into the factory wiring and attach to the P3 (This was what I had on another truck and it was simple with the adapter.)
You can find a lot of other threads in this forum on sway control and differing types. My honest opinion is that yes you will want some type of sway control. The effect on turning radius is minimal compared to the threat of a swaying TT. There are many different types and you don't necessarily have to go out and purchase an entirely new hitch, you might be able to add something to your current hitch for a limited amount of money. I wouldn't travel without it on a TT.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 02-17-2013, 03:11 PM   #3
MC9
You have the 4.30 rear end, you don't have to buy ultra lite anything. You might use the 4wd if you are stuck in some swamp. I would think you have the factory TBC (trailer brake controller) built in. (lower left center of dash). I pull a 5th wheel can't speak for a bumper pull.
MC9 is offline   Reply With Quote
Old 02-17-2013, 03:22 PM   #4
Dave_Monica's Avatar
Help if maneuvering of wet grass, mud, snow.
Help consume more fuel if towing in 4WD.
The Ford integrated brake controller works as well as the P3 I had in my previous TV...you won't need the P3.
I'd recommend W/D hitch with integrated sway control such as Reese dual cam or Equal-i-zer.
Dave
Old 02-17-2013, 03:24 PM   #5
4.3 gears must have been aftermarket installed as it wasn't a factory option in 2009. Sure they are not 4.10? Either way that will be a great towing machine. Congrats.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 02-17-2013, 04:01 PM   #6
Hmm, according to the info. on the door jamb, the Ford code number says it is a 4.30 limited slip. There's supposed have been 4 ratios available, 3.55, 3.73, 4.10 & 4.30.
I was wondering since the F250 has stiffer suspension, more load carrying capacity, is heavier and a bit longer (supercab in our case), perhaps the effect of wind isn't anywhere near as bad as a 1/2 ton truck?
Langley, BC
Old 02-17-2013, 04:06 PM   #7
That's news to me.
Yes to all.
Old 02-17-2013, 04:13 PM   #8
The 2009 Ford Fleet towing guide says 4.1 and 4.3... https://www.fleet.ford.com/showroom/...erDutyConv.pdf
Dave
Old 02-17-2013, 04:21 PM   #9
I thought the 4.3 was only available on the dually.
Old 02-17-2013, 04:35 PM   #10
caper's Avatar
Princess Auto have a friction sway control for $59.99. It is easy to attach to the trailer.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
f250
