Old 08-14-2016, 07:15 AM   #101
I have had them all. I would definitely go with the dually. You can learn to drive it and the safety factor of the 4 rear wheels is worth the aggravation of the extra width
Shrpram2 is offline   Reply With Quote
Old 09-12-2016, 05:55 PM   #102
Crbacsw's Avatar
A Fool Proof Method for Judging Tow Capacity: Polk's formula
I've been scouring the forums, reading varied opinions regarding towing capacity. Many with half ton trucks are pulling RVs with a dry weigh of nearly 9,000 lbs; some even bragging about being able to do so. Being able to tow it does not mean it is safe to tow it. Dodge rates my Ram 1500 Quad Cab at 10,000 lbs. towing capacity. That does not mean I can hitch up a 9k pound RV and take off for a cross country trip!
Determining safe towing capacity of a vehicle can be confusing. Polk's Towing Capacity Formula is an easy, reliable formula to determine SAFE towing capacity. Using his formula, I determined it was not safe for me to pull a 9,000 pound RV even though my 1/2 ton Hemi equipped Ram Quad Cab truck is at the top in its class for torque, power and towing capacity. According to Polk's Formula, I can safely tow a dry weight of under 7,000 lbs. That leaves plenty of room for storage, passengers, etc. without having to fret too much about exceeding the capacity. Just my 2 cents.
https://rvingwithmarkpolk.com/2012/0...wing-formulas/
Crbacsw is offline   Reply With Quote
Old 09-12-2016, 06:06 PM   #103
It is actually quite easy: go to a scale and weigh your tow vehicle. Subtract GVWR from actual weight: that is how much you can carry.
To get more granular: subtract GAWR from actual axle weight. That is how much you can put on the axle.
Once you get close to one limit, you may be over on another. Just watch all of them.
Weigh, weigh, weigh. Easy peasy.
For some reason, people don't want to spend $10 to know the facts.
325BH is offline   Reply With Quote
Old 09-12-2016, 06:46 PM   #104
Too Tall's Avatar
My formula is divide the OEM's tow rating by half. Just my opinion, I don't think you can have too much truck. Headwinds, grades etc...
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 09-12-2016, 06:50 PM   #105
CaptnJohn's Avatar
1st is to check the number most likely to go over ~~ payload. Check the yellow sticker on the TV driver door pillar. A 9000# TT will have over 1000# on the hitch and a 5er 1650 or more.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-12-2016, 07:34 PM   #106
Crbacsw's Avatar
Your method is clearly a very safe thing to do. Based on my VIN, Dodge rates my truck at 10,000 pounds. Using Polks formula, I come up with a safe towing dry weight of 6400 pounds.
Old 09-12-2016, 08:20 PM   #107
Flybob's Avatar
Towing capacity and max load capacity are two very different things.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-12-2016, 08:29 PM   #108
Too Tall's Avatar
My general point is, IMO, MFG ratings are way too generous.
USMC 68 -70
Old 09-12-2016, 08:29 PM   #109
CWSWine's Avatar
Max Tow is GCWR -Minus- Truck ready to go camping = MAX Towing Capacity.
Max Payload is GVWR -Minus- Truck ready to go campng = Max Payload Capacity.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-13-2016, 05:38 AM   #110
Coachman 312BHDS
Now the manufacturer's ratings are wrong? Come on folks quit giving bad advice on here.
2016 Coachmen Freedom Express Liberty Edition 312BHDS (37')
2014 F150 Lariat 3.5 V6 Eco Screw max tow - Century hard cap - Husky Centerline TS WDH
tbln930 is offline   Reply With Quote
