Old 09-13-2016, 07:06 AM   #111
CWSWine's Avatar
Originally Posted by tbln930 View Post
Now the manufacturer's ratings are wrong? Come on folks quit giving bad advice on here.
Here is the place you can get the facts----
Matching Trucks to Trailers
Safety is critical when towing an RV Trailer. This training video discusses the importance of understanding a Truck's ratings and how these ratings limit the size of the trailer that can be safely towed. You will be provided the tools and basic understanding needed to assist your endeavor to properly match a truck and trailer, so that you can enjoy RVing safely.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-13-2016, 08:43 AM   #112
Coachman 312BHDS
Good site for the newbie. In the end you have to weigh your rig together and the TV by itself and crunch your units specific numbers as painful as that might sound (it is not). These quick rule of thumbs and general guidelines are often misleading and mainly incorrect.
2016 Coachmen Freedom Express Liberty Edition 312BHDS (37')
2014 F150 Lariat 3.5 V6 Eco Screw max tow - Century hard cap - Husky Centerline TS WDH
tbln930 is offline   Reply With Quote
Old 09-13-2016, 12:16 PM   #113
Too Tall's Avatar
Trailer weight rating are a major marketing point. MFG's each had their own ways of determining how much weight their vehicles can tow, but there was no testing standard for all of them to follow. The SAE J2807 test is suppose to help standardize the test. But I think it's a suggestion not a requirement. The SAE test is all about how fast a truck will launch at given conditions. And maintaining a speed on a grade etc... It doesn't address wind resistance. Nothing about durability is another of my biggest want-to-knows. The SAE J2807 has only been around for about a year anyway. I guess one should ask the dealer if the truck meets SAE J2807, prepare for a blank stare. ha
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 09-13-2016, 12:28 PM   #114
Land of the Midnightsun
jjSpeedwagon's Avatar
I can't believe a lot of y'all referring to your pick ups as 1/2. 3/4 or 1 ton. That is old school when i was a kid and hasn't applied to any pick up built in more than 25 yrs.
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 09-13-2016, 12:57 PM   #115
Coachman 312BHDS
Exactly. Thanks. So much misinformation here. At least Ford 150, Ram 1500, gmc and Chevy 1500, are now rated to the J2807 standard. The F250 and F350 were not until the redesign in 2017.
Old 09-13-2016, 03:55 PM   #116
Another thing that never mentioned about weight and balance then moving it down the road is static and dynamic weight. All placks on every vehicle, trailer or any other machine in our world with any kind of weight rating is STATIC weight. Then you put that static weight in motion it becomes dynamic weight. So when Cheverolet says u can put 3500k on your axial you sure can. But when you go down the road the situation changes I was a crane operator most my life I retired from the North Slope in Alaska. I ran 2 of the largest single boom cranes on the continent I am very familiar with static and dynamic weight and a lot of things I read on these forums about pick ups and trailer are misleading fo sho. My 2 cents
John & Janice
Old 09-13-2016, 04:33 PM   #117
Coachman 312BHDS
The latest J2807 Tow Tests are pretty rigorous. Acceleration, grade, braking, steering (or rather the weight of the trailer tendency to steer the TV), and many other performance parameters are tested under towing loads. I went to direct to Ford's towing rep when I sized my truck. He pointed me to the J 2807 testing for the F150. After going through it all last spring I would say that Fords current (2014 and newer) F150 published towing numbers are pretty conservative. Too Tall is correct in that the marketing folks pretty much did the final specs before they started adhering to the current standard. Ironically, in many cases the trucks tested better than the marketing folks had been setting because of the fear of liability.
Here is an article on the testing process
SAE J2807 Tow Tests - The Standard
Old 09-13-2016, 04:51 PM   #118
Say what???
So you're telling us that the GM/Ford/Ram/Toyota engineers haven't taken into account the fact that the 3.5K (not 3500K I hope) on your axle is NOT moving down the road? You're right, the situation changes from static to dynamic, but to make us believe that the engineers don't account for that in their ratings is BS. It would make zero sense, and as Judge Judy says, "If it doesn't make sense, it's not true."
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 09-13-2016, 06:51 PM   #119
Originally Posted by rockfordroo View Post
Say what???
What I said was that little plack on your pick up is a static weight rating for maximum weight for that pick up standing still. Not in motion. Rest is up to you I've never seen any engineer rating saying this chev pick up will pull 10k at 70mph no prob. Or any other speed.
John & Janice
Old 09-13-2016, 07:51 PM   #120
I'm an engineer and I've done static and dynamic calculations. If you're telling me that the engineers don't design the vehicle brakes to handle the "dynamic weight" associated with the "static" weight that they put on their plaque (actually, in this case, it would be mass, speed and thus momentum and would concern the ability of the brakes to deal with the heat dissipation necessary to stop the vehicle a the GCWR - and moving at legal highway speeds), or design the frame, axles, etc to handle the "dynamic weight" at legal highway speeds, then I throw the BS flag.
What you're calling the "dynamic weight" is inherent in the static value they give you. They don't need to give you any "dynamic weight." The average vehicle owner would not know what to do with it. (Heck, half the people don't understand simple "weight.")
You don't see bridge limits that say "10 tons - but only 8 tons if you think you might hit a bump on the bridge."
As a crane operator, you may have to had to deal with something like "dynamic weight," (I'm guessing it has to do with the load swinging from the cable) but your average vehicle owner can't be expected to do that. It has to be built-in and it is.
