10-10-2011, 08:13 PM
Brigitte
A New tire question
I realise wrangler HP 20" tires aren't the best for towing but...
When I left, I had 37 psi in tires and after 2 hours of driving (55 mph/hr), psi was up to 42. Is that normal? Tires are rated for a total of 45 psi.
I will get new tires in the spring, but curious.
Shasta Revere 21FBS LE
2010 Dodge Ram SLT 1500 QC 4X4 HEMI
Sheltie, Chihuahua and a Mr. Mutt
Kingston, Ontario
Days reserved 2012 (so far) 30 Days camped 2012:
10-10-2011, 08:18 PM
Typically the max air pressure rated at cold, so increases in pressure under operating temp should be factored in. I could be wrong so hang tight for more experienced members to reply.
 Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
10-10-2011, 08:20 PM
Moderator
The short answer is, yes, tire pressure will rise as you drive.
But your tires were probably getting a little too hot from the underinflation (37psi was too low to begin with). Fill them to their rating, which in your case is 45 psi (cold).
Scott
DW, DD's x 3 and Murphy the Camping Dog - A Golden
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD, P3, Equal-i-zer
10-10-2011, 08:26 PM
Brigitte
In door it says inflate to 35 psi cold and max pressure 45
Kingston, Ontario
10-10-2011, 08:34 PM
I'm assuming you are referencing the tires on your toe vehicle. Remember that when towing, or carrying near max payload many manufacturers recommend higher tire pressures (cold). Check the owners manual and door jamb for recommended cold pressure at max payload.
 Jeep4Two
10-10-2011, 08:35 PM
Brigitte
Ah I see. Ok thank you
Kingston, Ontario
10-10-2011, 09:11 PM
Moderator
Sorry - I should have asked for more information. I assumed (and see where that got me  ).
The first number is the proper tire pressure for your vehicle - the "recommended cold inflation pressure."
This on maximum inflation pressure might help.
Scott
2012 Shamrock 233S
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 572 |
| 121 members and 451 guests |
| 2000XLifted, 4Jeeperz, 5Galvs, acadianbob, autorot8, bean, bear17, Bearcat55, BlakeB, bob34787, bob7794, Borwick, boubou, bryndlwulf, Busman1947, buzzmonster, camper_Lucy, caper, Capsfloyd, Cascade Bob, cat1956, cdbus, Char_n_Kath, comfun1, condo, Cowracer, cstover, DAISY BOYKIN, danred, DAREK.NIEUWSMA, dasimser, dec1952, dimurrrw, dnicekid, Douglasdh62, Drmstx62, DSN46, dtolar, duchie, dunnnc, elind, flc, fordmantpw, FreedomTracker, gbpacker, GeorgieGirl, gmurrell, Gquist, gsocamper, Hammertat, Happy Vibe, herk7769, hokiecampers, icebrew, isz, JamesR, Jeep4Two, JJones, jkinger, jmswms, JoeR, joess, Joker, jphillips1075, judy3972, kegoneill, LFugate, lmcleister, louincal, Love2run, maggiek, micalo, Mr. Legato, MT28rk, mtl roofer, munty, NanaKaren, NancyTX, pandkm, Pharmofish, phuss, Pinesman, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, prof_fate, punkaccountant, pwrplay, rawlus, Redheaded blue tick, Rescue1, rickthelen, rjshiflet, rschoono289, rstewart06, russpat, rwzahm, Sailfish Bret, sbond, SDENN4281, shineysideup, Skippkon, skippy31405, softwarejoe, Stagger, Stank Bait, Stinger, Tech Admin, texashatter, thaithco, tmmar, TN_Jeeper, Triguy, vinman72, wakamicamper, william.migues, willy, wneise, wvfireboss |
| Most users ever online was 996, Yesterday at 11:04 AM. |
