Old 05-17-2016, 08:14 PM   #11
CaptnJohn's Avatar
Forget the Tundra, not even close! You are into 3/4 ton territory. I'd prefer a Ford but the 2500 will be fine. I'd also prefer a diesel but that gasser will do the job OK. Look hard at the 5ers,,, much nicer to tow. I traded up from TTs to a 5er then to a class A MH. Traded UP to a 5er again.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 05-17-2016, 08:22 PM   #12
northstar1960's Avatar
forget the tundra not enough truck , need a 3/4 ton go Chevy as i prefer them over the others all though the ford would be ok the diesel is ok but the 6.0 will handle it very well , easier to maintain , less cost for services and good for 300,000 miles
northstar1960 is offline   Reply With Quote
Old 05-18-2016, 11:41 AM   #13
Why mess around?
We got a Ford F450 dually diesel that will tow about anything towable. Why not have all the truck you'll ever need?
breezyhillfarm is offline   Reply With Quote
Old 05-18-2016, 12:24 PM   #14
Maron
Send a message via Yahoo to Maron
Love our Tundra
The question is is that your loaded weight or empty?
We have a 2013 Tundra Limited 4x4 towing a Rockwood 8329ss empty at 7600 lbs. loaded I would guess close to 10,000 lbs. been doing it for 3 years and very happy with the performance but even happier with the ride. The Tundra is like riding in a limo. We love it!
Maron is offline   Reply With Quote
Old 05-18-2016, 01:07 PM   #15
Might even want to look at a "PETERBILT or a KW"! Then you can pull any thing and probable want even know it's back there! LOL<
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is online now   Reply With Quote
Old 05-18-2016, 01:12 PM   #16
NMWildcat's Avatar
I'll repeat what I've read and experienced: Once you get into toy haulers and fifth wheels, a 1/2 ton is never enough. I tried really hard with my first few RVs to pull them with my gas 1/2 ton. When I finally gave up and went to a 3/4 diesel I kicked myself for waiting so long. You won't believe the difference in towing experience.
And seriously, forget the Tundra. My son has one and so do several of his friends. They all experience the same thing: does a good job towing smaller trailers but the gas mileage is horrendous. When their Tundras are empty (not towing) they get the same mileages as I do towing! Not even an exaggeration. And when they are towing, they can't pass a gas station. So I would research that if you are really considering the Tundra.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 05-18-2016, 01:21 PM   #17
Originally Posted by davel1971 View Post
you can get a single rear wheel 1 ton for basically same price as 3/4 ton. MUCH more payload and same ride quality. I had one before I went dually and it would handle a mess of weight.
This didn't hold true for me. When I bought, there were great incentives on the 2015 models- to the tune of several thousand dollars MORE than the 2016's. Dealers typically stock dozens of 3/4 ton for each 1 ton SRW. So there was still a very good selection of 3/4 tons and almost no 1 tons. If I'd had no preference for color and was very flexible on options- which I wasn't'- I could have bought the SRW 1 ton. But I would have still paid a significant amount of money for options I didn't really want. With that being said, I saved ~$3K going with the 3/4 ton even though the 1 ton is only $1K or so higher per the sticker. On top of that, mine has the camper package, so it's actually IDENTICAL to the 1 ton SRW. I just couldn't justify spending an extra $3K for an IDENTICAL truck with a bigger number on a sticker, so I have an F250. For much of the year, however, you are correct.
Old 05-18-2016, 01:40 PM   #18
We started out with a Tundra. It was great towing a 19' toy hauler. Then we moved up to a 24' toy hauler. The Tundra pulled it, but the hills in Arkansas made it scream. Then moved to a Ram 2500 diesel and pulled it like it was nothing. We now have a 36' toy hauler and the truck does great. I learned the hard way should have started out with a 3/4 ton diesel.
XLR 24 HFS
Bpenn is online now   Reply With Quote
Old 05-18-2016, 04:04 PM   #19
There's too many blogs on TVs. Go to your favorite dealer and ask to see TVs with payloads over 3,000 if your looking at a 5er, look at the driver door post sticker (just cause it's a diesel doesn't mean the payload is over 3,000). 10,000 5er pin could be 1,400 to 1,800 pin and hitch 150 - 300, so you're looking at 2,100 before you, family and loads of stuff (up to 900) before you get going.
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 05-18-2016, 04:50 PM   #20
mike.t's Avatar
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
5er
