05-17-2016, 02:04 AM
A pickup to tow a 10K lb TT or 5er
The 1st I'm considering, is a new 2500 Reg Cab, Long Box WT RWD, 6.0L V8 (360 hp & 380 ft-lb torque) Curb Weight 5817 lbs, Max Payload 3534 lbs, Max GVWR 9.3K lbs. W/Conventional tow rating of 14.5k lb w/4.10 rear gears.
The other is a Toyota Tundra, 2WD Reg Cab, Long Box, w/5.7L V8 (381 hp & 401 ft-lb torque). Curb Weight 4940 lb, Max Payload 2060 lb, GVWR lb 7K &
Max tow cap is 10.5K lb (w/4.3 rear gears & towing package).
10K is the GVWR of the RV. It should way more like 8.5K loaded. I'm wondering why with more torque & a higher axle ratio, the Tundra is rated so low on towing. Anyone have any ideas why this would be the case. I'm staying away from turbocharged gas engines. I don't believe they are worth the loss of dependability they cause. The Tundra has an all aluminum block, I doubt it last as long as an iron block.
Any idea which of these two work work better and be the better buy?
05-17-2016, 03:15 PM
The 2500 hands down! You can't compare a 1/2 ton with a 3/4.
05-17-2016, 03:21 PM
If 5'er, depends on the pin weight of the loaded camper. The 2060 of the 1/2 ton will make you upside down before you start. The 3534 of the 3/4 ton might give you a little room for cargo, depending on pin weight. Those two numbers must be equitably satisfied before you discuss tow capacity numbers.
FROG AR-0019-242
05-17-2016, 03:22 PM
you will run out of payload quickly on the Tundra with a 5'er
Go 3/4 and consider Diesel if you ever think you may upgrade
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
05-17-2016, 04:02 PM
If your going to pony up to a diesel , then get a one ton DRW . Better to have to much truck , then not enough.
05-17-2016, 05:33 PM
I also agree, the 1/2 ton going to come up short at 10,000 and the gas 3/4 will handle it nicely.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
05-17-2016, 05:51 PM
Georgia Rally Coordinator
Here we go again. Bring on the pop corn Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
05-17-2016, 05:57 PM
I see the 3/4 tons and raise a 1 ton.
More play room now and perhaps latter in the event a bigger trailer follows you home one day.
05-17-2016, 06:12 PM
Having just gone through this after weighing with my 1500, not 2 weeks ago, I traded for a used 2500 Diesel. Slight difference was both crew cabs vs reg cabs and didn't go with an 8' bed either. Good luck!
05-17-2016, 08:03 PM
you can get a single rear wheel 1 ton for basically same price as 3/4 ton. MUCH more payload and same ride quality. I had one before I went dually and it would handle a mess of weight.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
05-17-2016, 08:14 PM
Forget the Tundra, not even close! You are into 3/4 ton territory. I'd prefer a Ford but the 2500 will be fine. I'd also prefer a diesel but that gasser will do the job OK. Look hard at the 5ers,,, much nicer to tow. I traded up from TTs to a 5er then to a class A MH. Traded UP to a 5er again.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
05-17-2016, 08:22 PM
forget the tundra not enough truck , need a 3/4 ton go Chevy as i prefer them over the others all though the ford would be ok the diesel is ok but the 6.0 will handle it very well , easier to maintain , less cost for services and good for 300,000 miles
05-18-2016, 11:41 AM
Why mess around?
We got a Ford F450 dually diesel that will tow about anything towable. Why not have all the truck you'll ever need?
05-18-2016, 12:24 PM
Maron
Love our Tundra
The question is is that your loaded weight or empty?
We have a 2013 Tundra Limited 4x4 towing a Rockwood 8329ss empty at 7600 lbs. loaded I would guess close to 10,000 lbs. been doing it for 3 years and very happy with the performance but even happier with the ride. The Tundra is like riding in a limo. We love it!
05-18-2016, 01:07 PM
Might even want to look at a "PETERBILT or a KW"! Then you can pull any thing and probable want even know it's back there! LOL<
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
05-18-2016, 01:12 PM
I'll repeat what I've read and experienced: Once you get into toy haulers and fifth wheels, a 1/2 ton is never enough. I tried really hard with my first few RVs to pull them with my gas 1/2 ton. When I finally gave up and went to a 3/4 diesel I kicked myself for waiting so long. You won't believe the difference in towing experience.
And seriously, forget the Tundra. My son has one and so do several of his friends. They all experience the same thing: does a good job towing smaller trailers but the gas mileage is horrendous. When their Tundras are empty (not towing) they get the same mileages as I do towing! Not even an exaggeration. And when they are towing, they can't pass a gas station. So I would research that if you are really considering the Tundra.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-18-2016, 01:21 PM
This didn't hold true for me. When I bought, there were great incentives on the 2015 models- to the tune of several thousand dollars MORE than the 2016's. Dealers typically stock dozens of 3/4 ton for each 1 ton SRW. So there was still a very good selection of 3/4 tons and almost no 1 tons. If I'd had no preference for color and was very flexible on options- which I wasn't'- I could have bought the SRW 1 ton. But I would have still paid a significant amount of money for options I didn't really want. With that being said, I saved ~$3K going with the 3/4 ton even though the 1 ton is only $1K or so higher per the sticker. On top of that, mine has the camper package, so it's actually IDENTICAL to the 1 ton SRW. I just couldn't justify spending an extra $3K for an IDENTICAL truck with a bigger number on a sticker, so I have an F250. For much of the year, however, you are correct.
05-18-2016, 01:40 PM
We started out with a Tundra. It was great towing a 19' toy hauler. Then we moved up to a 24' toy hauler. The Tundra pulled it, but the hills in Arkansas made it scream. Then moved to a Ram 2500 diesel and pulled it like it was nothing. We now have a 36' toy hauler and the truck does great. I learned the hard way should have started out with a 3/4 ton diesel.
XLR 24 HFS
05-18-2016, 04:04 PM
There's too many blogs on TVs. Go to your favorite dealer and ask to see TVs with payloads over 3,000 if your looking at a 5er, look at the driver door post sticker (just cause it's a diesel doesn't mean the payload is over 3,000). 10,000 5er pin could be 1,400 to 1,800 pin and hitch 150 - 300, so you're looking at 2,100 before you, family and loads of stuff (up to 900) before you get going.
DJsFolly
05-18-2016, 04:50 PM
