Old 01-13-2014, 07:26 PM   #11
pjones1969's Avatar
Originally Posted by Ford Idaho View Post
How easy is it to get that hitch in and out?
Super easy, remove the head, loosen 4 bolts, remove 1 hold down bolt, pull the pin and it's out, the new design they have now doesn't require any tools to remove so it would be even easier.
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 01-13-2014, 07:28 PM   #12
Phat Phrog Stunt Crew
mackman1994's Avatar
I would go with the B&W hitch. I think in about 90% of all situations you will be fine without a slide hitch. you may still want to go with a B&W slide hitch for that other 10% because it is always better to have it and not need it than to need it and not have it. I just pulled my first fiver home last Friday. I run a 2012 F-350 with 20 in wheels they are 10 ply tires and have no problem with clearance. Here is a pic. Sorry about the quality.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 01-13-2014, 07:32 PM   #13
I have the new version that fits in Ford's factory prep. The hitch just drops into the four pucks and twist the handles toward the hitch and put the pins in. This is all done from inside the truck bed. Love my B&W!!!!!
Old 01-13-2014, 09:04 PM   #14
Oklahoma Proud
MillerTime's Avatar
We had a puma 5er, and are also looking at ordering a 36qbok in a couple weeks.
We have a companion (non slider) in our shortbed chevy (in the rearward most setting) and have hooked up to Sabres. U cant turn 90% but you can turn pretty tight.
On the wheels you are fine. Factory wheels are rated to handle at least the gvwr. And 20" wheel and tires will actually have stiffer sidewalls, because there is more wheel and less tire. Some people think that larger wheels equates to larger tires- but actually most stock tires on a certain lineup of trucks will all be very close in diameter (usually within an inch) regardless of wheel size, rather it be a 17" wheel or 20" wheel.
Old 01-13-2014, 11:15 PM   #15
jtstromsburg's Avatar
I pull a 34tbok with a Ford shortbed, companion with no problems. Only one season, but never even came close to cab/camper contact. That said, had the companion slider been available last march, I'd have it instead of my original non-slider version.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-14-2014, 07:17 AM   #16
Pirates55's Avatar
I see the cost of the B&W slider and the pullrite system that mounts in the B&W turnover ball that is automatic are about the same price. I already have the turnover ball installed so I'm really considering the pullrite autoslider just for the peace of mind. We go to Myrtle Beach and if you don't get an end campsite you really have to almost jake knife the trailer to get it backed in. At least I did with my travel trailer.......the 5er may be different.
Pirates55 is offline   Reply With Quote
Old 01-14-2014, 08:37 AM   #17
Fulltime family RVer
IMO, the slider is just good insurance. You may not need it, but as long as you maintain it- it's there when you want it.
BUT- there's a whole thread/raging debate on it.
As much as I love my B&W, if I had a slider- I believe that I'd have an automatic so it just does its thing.
ependydad is online now   Reply With Quote
Old 01-14-2014, 08:50 AM   #18
Pirates55's Avatar
Where is the thread located about the debates of sliders, etc....
Old 01-14-2014, 08:57 AM   #19
Here ya go:
Can I beat the Sliding hitch vs fixed hitch Thread to death again?
Old 01-14-2014, 11:46 AM   #20
sonic2's Avatar
Originally Posted by Pirates55 View Post
My wife and I are about to order our first 5th wheel, as we sold our travel trailer last summer. We are ordering the Sabre 36QBOK. My questions are centered around this:
My 2007 4 door F-350 4X4 came with the factory 20 inch wheels and its a short bed. It has the airlifter 5000 air bag kit on it and also the B&W Turnover ball
I can't decide on a hitch set up. My truck has the B&W Turnover Ball already installed, so I want to use it with what ever hitch I go with. I've read about the Pullrite superglide 16k that has a kit that will utilize the turnover ball.
I have a B&W Turnoverball Gooseneck Hitch and a Anderson Ultimate 5th Wheel Connection hitch; SuperSprings and Timbrens on rear of my F150 (all made in the U.S.A.), I have a Reese Revolution on my 2014 Rockwood 8289.
The maneuvering with turning and parking is easy and more than enough room between the cab and front the 5th wheel. Overall I am very satisfied with the performance of all products. You stated you want to use your turnover ball and you've pulled a trailer; this product is light, easy to install and remove and uses your turnover ball. Check their web site, it has videos and information.
2014 Rockwood 8289WS - Goodyear Tires
2013 F150 crew 4x4 5.0L 3.73 6 1/2 bed
Supersprings & Timbren & B &W Turnoverball
Anderson Ultimate 5th Wheel Connection Hitch
sonic2 is offline   Reply With Quote
5th wheel, sabre, wheel
