Old 05-04-2015, 07:34 AM   #11
Originally Posted by Bilcin View Post
Yes, WDH is rated to 12,000lb just had to upgrade my spring bars from 800lb to 1,200lb bars and
I am not sure what hitch you currently own, but if it were me towing that size trailer . . . I would want to tow it with the best hitch/sway control I could afford. I would personally buy a The Equal-I-er hitch and sell the old one to recoup some of that investment.
madmaxmutt is offline   Reply With Quote
Old 05-04-2015, 07:49 AM   #12
+1 on the hitch upgrade. Equalizer 4 point- RVWholesalers has them and is very competitive on pricing. ProPride or Hensley would be best, but they don't give them away.
Old 05-04-2015, 08:17 AM   #13
DFW Rusty's Avatar
I'm with OldCoot. Get a reputable welder to weld it on for you. When I bought my second sway bar it came with the tab, luckily my hitch already had the hole for the ball, so it wasn't needed.
I am sure that one of the expensive hitch setups will work better, but I have the WDH chains and 2 sway bars and my 6700 lb, 33' camper pulls straight as an arrow.
2015 WildWood 27RKSS
2012 Ford F350 King Ranch FX4
DFW Rusty is offline   Reply With Quote
Old 05-04-2015, 08:27 AM   #14
The OP is probably close to 3K heavier and 3' longer.
Old 05-04-2015, 08:31 AM   #15
Not everyone can spend upwards of $2000+ for hitches when a $100 fix will work.
Old 05-04-2015, 08:39 AM   #16
You can find HA's and PP's used for $900-$1500 if you look. The OP will probably have $500 in their entire setup before it's over. That's at LEAST 1/3 the cost for 1/50 the hitch, IMHO. Considering a new 5er would run probably 30K+, I think that's a little stretch of a comparison. Also, one thing that no one ever seems to consider is this- the more friction you use to control sway, the more you have to overcome in order to turn. People need to consider that the force used to control the sway will still be there acting against them if they need to make emergency maneuvers or if they encounter slick roads. I believe the friction bars actually state NOT to use them in wet/icy conditions.
Old 05-04-2015, 09:10 AM   #17
Try again...
Name:	Sway control.jpg
Old 05-04-2015, 01:55 PM   #18
Stormrider151's Avatar
The picture you posted looks like a Reese hitch. Can you just add the cams to your current hitch?
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-04-2015, 02:38 PM   #19
Edit: Didn't follow or read carefully resulting in stupid post. Deleted. Carry on.
Old 05-04-2015, 02:48 PM   #20
In answer to your question, I don't believe you can just add cams without adding the other hardware needed for the cams.
sway
