Old 09-14-2016, 06:24 PM   #21
Usually Confused Member
emm-dee's Avatar
Originally Posted by jftrombley View Post
If you want a camera you can see behind you all the time, this will not work since it has a backing light and people following you won't like that too much.
Little bit of black spray paint or some electrical tape. Problem solved.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 09-14-2016, 07:47 PM   #22
Backup Wireless Camera for TT
Went with the cheap one - dont waste your money. It's worth it to get the Furion FOS48TAPK-BL
I have it adjusted so you can see the tops of both rear tail lights abdcabout 15' out.
No interference on my F-150 mounted display. I did add an on/off switch in the TT otherwise the camera stays on as long as the 12 volts is on. The manual says you can take power from marker lights but did not work for me - dealer said not enough juice!
Ran the power from an interior light behind the rear wall.
Malabarbob is offline   Reply With Quote
Old 09-14-2016, 08:18 PM   #23
Bought a Magellan 9250LT GPS with lifetime maps. available is a wireless backup camera that goes over the license frame. Wires to the back up light for power. Very pleased, works great, has Bluetooth connection to your cell phone also. Paid less than $300.00 on amazon. easy to install. Have had about a year, no problems. Have used Magellon GPS units for over 5 years no issues
Lee Hartwig
Ford V10
2009 Forest River Lexington
windowman is offline   Reply With Quote
Old 09-14-2016, 08:49 PM   #24
dea49's Avatar
I am in the process (stalled for a different repair problem) of installing a backup camera on my 26' TT. I am running the video/power cable through the roof accesses from front to back, I am placing the transmitter in a cabinet in the front, cutting down drastically on the distance and interference the transmitter has to send through.
I got this idea from a friend of mine who couldn't get an expensive wireless camera to work but after doing this he uses a $20 transmitter and receiver combo hooked up to a $10 camera. It works perfectly!
I wired mine to a SPDT switch on the dash instead of the brake lights so I can choose between my backup camera on the license plate and the one I'm putting on my TT. It sends my signal to a rear view mirror with color LCD display.
2007 Rockwood UltraLite 2603
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
dea49 is offline   Reply With Quote
Old 09-14-2016, 09:29 PM   #25
emm-dee's Avatar
Originally Posted by Boborc View Post
I was starting to look at something like this. https://www.amazon.com/dp/B01IOL27TI?psc=1 The only thing is I would be adding another screen to the truck. Wondering if there is a wifi camera that will run off 12v and work with android so I can use my phones screen. Thats kinda why I was looking at the Garmin since I use a compatible Garmin GPS and could use same screen. The only thing is they say the transmitter must be in line of sight to receiver, was wondering if anyone has used the Garmin Bkup camera.
Since there are several million iPhone and Android smartphones in use it amazes me that few makers of rear view cameras are using them. A few thoughts and comments:
The smartphones are not a good device for displaying images sent by bluetooth. RVs are just too long to have reliable bluetooth coverage.
They are not compatible with the majority (probably all) of the available cameras operating techniques to deliver the image.
If one gets the smartphone up and running as a monitor (which I'll describe how to do) then you have a display that is far superior to ANY monitor supplied with standard backup/observation cameras. I don't know anything about Android devices so I talking about iPhones with Retina display. Wait...I know something about Android, which is I'm just not smart enough to figure out how to use it. Tried a few of them and the user interface was a mystery to me.
One of the few cameras advertised as WiFi (from Tadi) looks good but it has, for most of us, a big drawback. Yes, it is WiFi, but the wifi transmitter (router) box has to be physically connected to the camera. In most cases it is extremely hard or (as with my TT) impossible to run any wires for a camera. It would be nice to be able to run wires so one could use a direct wired camera which is generally superior to wireless models.
Here's how I solved the problems, but it does take a little work. A few pictures are attached. I installed a Sharx 3904 security camera. It is powered by either a Cat 5 cable OR any 12 vdc power. The camera is way ahead of the others because of its 1080p b/g/n transmission capability and has a resolution of 1920x1080.
Since it has its own built in wifi transmitting capability all you need to do is tap off one of the running lights. If your RV came with the pretty much standard Furion prep then there's already a 12 volt wire inside the mounting box that comes alive whenever the running or head lights are on. Once it wakes up, the camera searches for and automatically wirelessly connects to a wifi router. Configuring this system is an easy process.
Now, with the camera up and running you will need your own wifi network installed in the trailer. Easy, easy, easy. I put in a Netgear R6400 router. Like the camera it also gets it power at 12 vdc. Both units come with a 120 volt AC plugin thingy but all that is is a converter. Cut the cords and wire them direct to 12 volts and the units don't know the difference. I mounted the router in one of the forward overhead cabinets in the front bedroom. Power came from the light over the bed and I put a micro switch in so I could turn the router off whenever I don't need it. I can connect to the router wifi out to about 200 feet with my iPhone/iPad.
Now, get it to the iPhone. Two ways...Safari (or for other devices any internet browser) or an app that can be downloaded from the app store or Google Play (I think that's what the Android app store is called). In Safari just put 192.168.1.2 in the http address bar and you are instantly connected to the camera. You have the option to go to settings to set it to your preferences (which are saved) or go to direct view. The Safari/Chrome/IE/Firefox systems are generally used for setup because they all have an unacceptable delay when viewing (about two-three seconds). Using an app (I use MobiLink or LiveCams) still has a delay but its well under one second. Most wireless systems have delays of some sort and the only way around that is a direct wired system.
An added benefit of this system is the camera has standard built in recording capability. It uses an easily accessible internal SD card and, depending on resolution or card size used, continuously records everything it sees for 8-12 hours. Well, it's easily accessible if you don't mind climbing a ladder to open up the camera to remove the card. You can download or view (on smartphone/pc) the video files but they are pretty big..+/- 150 mb each so it takes a minute or more to get to them.
So, it's not for everyone and it's not really cheap (figure about $320 or so for the camera and a top quality router), but if you want to use your smartphone or tablet I think it's the best option available.
Heres the camera:
https://www.amazon.com/Sharx-Securit...ecurity+camera
or, for wider view (better if you want to use it for backing into a campsite, but remember objects in mirror are closer than they appear).
Overall view of the camera position (ignore the antenna on the far left side of the TT...that's used for the Alpha CampPro wifi repeater):
Closer view:
iPhone in use:
iPad mini in use:
Old 09-15-2016, 03:31 AM   #26
Coachman 312BHDS
Omg. I would rather shoot myself than do all of that. Lol I use and rvs camera w/ gel cell with a magnet on the bumper. It is 2.4ghz to its own display in the truck. Works perfectly and easily. The only negative is to put the camera out there. You can mount it permanently to a tail light but that is unecessary.
2016 Coachmen Freedom Express Liberty Edition 312BHDS (37')
2014 F150 Lariat 3.5 V6 Eco Screw max tow - Century hard cap - Husky Centerline TS WDH
tbln930 is offline   Reply With Quote
Old 09-15-2016, 07:37 AM   #27
emm-dee's Avatar
Not that much work...less than two hours. The only problem I had was having to cut, paint and seal the aluminum plate to cover all the misdrilled holes FR did when they installed the Furion camera mount.
Old 09-15-2016, 09:15 AM   #28
Mrs Evans's Avatar
Originally Posted by emm-dee View Post
Closer view:
I'm curious, what is the square box next to the camera?
Thanks,
Michelle
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 09-15-2016, 10:04 AM   #29
emm-dee's Avatar
Thanks,
Michelle
The Sharx is intended as a home/business security camera so it has the capability to be used wirelessly or with an ethernet cable. The ethernet cable also supplies power.
There are two wires coming out of the camera for ethernet or power connection. Since the camera is so small, and must be waterproof, the box is included to house the connections when using it in a "wet" environment (i.e., the back of the TT while driving in a rainstorm). In addition to the waterproofing function I didn't want to cut off the ethernet connection so it wouldn't dangle in the wind. So, the ethernet and power cables go into one side of the box and the incoming power wire comes in the other side. It would not be necessary to use the box if mounted in a dry environment.
Old 09-16-2016, 09:32 PM   #30
I have the Furion, it's awesome!!
Krlpj05 is offline   Reply With Quote
