Adding Trailer plug to back if fiver
My 'Piper is at a friends place having a three position hitch added to the rear (two for swivel wheel and center one just in case I ever pull a utility trailer). I am now thinking through how best to add a flat four pole trailer plug at the back for the swivel wheel LED lights. Without having it here in my shop right now, I'm just brainstorming the best way....
Does the brake and turn signal wiring run along the frame, or inside the walls / ceiling? If on the frame, then this is an easy add.
Would it be best to simply tap into the wiring at or near the bed of the truck and run a new 4 wire flat cable (or another type cable) along the frame rail to the soon to be installed hitch?
Anyone done this? How did you do it?
I know this isn't difficult, but in the absence of the RV I am just planning. When I get it back (and get back in the country), I'll only have a couple of days before heading to the beach in it.
Thanks in advance.
