Old 08-11-2015, 08:08 PM   #31
CWSWine's Avatar
Originally Posted by walters View Post
do yall think it will pull it comfortably
So what is was the pin weight? A 350/3500 weighing of 8820 that leave 2680 cargo capacity to handle the pin weight so you will close but should be good. The truck weight seems high... You did say you have 350/3500 and not a 250/2500 if you have 3/4 ton that weights 8820 you probably will be way over your Cargo Capacity.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-11-2015, 09:45 PM   #32
weight
I have a 2010 dodge 3500 dually cummins with a cm flatbed right now, the bed probably makes it weigh that much, the weight difference on the back axle of the truck today was 2600 pds, so I guess that's the pin weight, the new 6.4 ram 2500 im thinking of buying has about a 3500 pd payload capacity.
walters is offline   Reply With Quote
