Old 01-11-2016, 10:12 AM   #1
Cool Air bag check light
I have a 2004 super duty. When I plug in my new FW to tow. The airbag light will blink and then stay on. Only when the FW is plugged in. I had two other FWs but never had this issue. I towed my father- in- laws TT once and it came on then. I'm guessing something with the units not the truck. Am I guessing correctly? Any suggestions?
KBUZ is offline   Reply With Quote
Old 01-11-2016, 03:43 PM   #2
The Big Toe's Avatar
Could be your brake controller.
Could be in the Trailer's Harness.
Could be in the Truck's Harness.
Could be in the Dash.
Could be a bad ground.
Could be in the Body Computer/Gem Module
Could be in the ignition switch.
Could even be something as silly as the chip in your Key. If you have another Ignition Key, try that one when you're having the problem again. Although that one's a long shot.
I believe in checking the easiest thing to fix first.
When it comes to electrical problems........ They can really be a problem.
Good luck
The Big Toe is offline   Reply With Quote
