Old 03-16-2015, 12:11 PM   #21
Kash76's Avatar
Cool thanks
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 03-18-2015, 06:59 AM   #22
Dodge 3500 I am usually about 30 pds when hooked. You do want the truck to set in a bit. The best ride seems when the truck is level loaded. it has a rake when empty( rear higher then front)
ammdrew is offline   Reply With Quote
Old 03-18-2015, 06:40 PM   #23
golfmedik's Avatar
35-55 pounds depending on road conditions..pin weight 3100#.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
pressure
