Old 02-18-2015, 07:25 PM   #1
jjgabe's Avatar
Air bag pressure
I just installed Firestone airbags on my 2013 Ram 2500. I tow a Stealth 2750. I know the loaded pressure will very depending on my load but I was curious what pressure most people ran when unloaded, and loaded for that matter.
Jason
jjgabe is offline   Reply With Quote
Old 02-18-2015, 07:39 PM   #2
Jerry427's Avatar
I have a 2500hd Silverado I run 10 lbs. when empty and 35lbs. when towing I have a 2015 silverback 37bh
Jerry427 is offline   Reply With Quote
Old 02-18-2015, 07:42 PM   #3
I run 15# which is just enough to keep the compressor from kicking on if I hit some bumps.
Old 02-18-2015, 07:51 PM   #4
BombDoc's Avatar
I have a 2011 Ram 2500 and run my ride rites at 10# unloaded. Loaded, between 30 and 40#'s usually levels it right out.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 02-18-2015, 08:51 PM   #5
got bags in my '04, run 10# 'empty' (5psi is the minimum allowed to prevent the bag from bottoming out and being destroyed) for my day-to day use. havent played with it much with the new trailer, as i havent dragged it around for any appreciable distance, i put 40psi in them when i picked up the trailer and it didnt even level out the truck. probably get away with ~30psi in them.
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 02-18-2015, 09:06 PM   #6
trbomax's Avatar
Ive had a ride right setup with compresser and tank on my sd since 2001.All original parts. I shut the compresser off and let the system down to 0 psi when I dont have the trailer hooked up.My bags dont have any cracks,splits and dont leak when inflated.
trbomax is offline   Reply With Quote
Old 02-19-2015, 09:14 AM   #7
f5moab's Avatar
5 psi, required minimum
f5moab is offline   Reply With Quote
Old 02-19-2015, 06:27 PM   #8
Mattpopp's Avatar
That is correct, Firestone recommends 5 psi when empty. Mine had a very slow leak from the switch. ran them empty most of their life when no trailer was present and never had a issue with them
2014 Cedar Creek 38FL
2012 F350 DRW,
1980 Wife
Mattpopp is offline   Reply With Quote
Old 02-20-2015, 04:14 AM   #9
searay245se's Avatar
10 empty 35 with a load on.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 02-21-2015, 10:32 AM   #10
Now a "Top Member"
EdJunior's Avatar
Yep...5psi unloaded. I have the wireless compressor, and it only goes down to 5psi...no lower. It also keeps the bags at whatever psi I have it set to. So it will maintain the 5psi unloaded. I typically run at 45 psi on the concrete highways around Houston (and other cities...but so far Houston is the worst). Then I bring them down to either 25 or 35 psi for cruising.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 02-21-2015, 10:43 AM   #11
I don't take mine above 25# anymore.. I had them close to 45# when I first put them in and took the trailer out to a local campground.. I found the set-up had alot of bounce and was definitely not as controlled as I was used to.. Down to 25# and life was good...
2015 GMC 1500 Z71
2013 26TBQB
Camped: 2024 (Days/Nights) - 4/3
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 02-21-2015, 10:45 AM   #12
Dakota EV's Avatar
I set my air bags at 10# empty and 35# loaded for my 5th wheel. This works great for me.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 Diesel
TMPS for Camper & TV
Dakota EV is offline   Reply With Quote
Old 02-21-2015, 08:29 PM   #13
jjgabe's Avatar
Thanks for the inputs. I have been running with 7 around town empty. I am going out to Glamis this weekend so I will try a few pressures. Going to start out at 30 and adjust every 30 or so miles to see what feels best.
Old 02-28-2015, 08:24 PM   #14
Dan'l Boone's Avatar
I just ordered the Air Lift Load Lifter 5000 bags for my F-250. Recently upgraded from a bumper pull to a 5th wheel and had a bunch of people flashing their lights at me when I pulled last trip. I didn't think it squatted that bad, but it's enough to affect my lights for sure. I think the ride will be better as well. So after reading countless forum posts here, I decided to order a set of air bags. I read somewhere that you'll never know how nice it is to own a 5th wheel unless you towed a bumper pull first. Now that I have one, I concur. I hope having air bags is a similar experience. Can't wait to get/install them, and try it out.
2015 Shasta Phoenix 28BH
2013 F-250 4X4 6.2L Gas
Reese Pro Series 20K# 5th Wheel Hitch
TrailAir Rota-Flex Pin Box
Dan'l Boone is offline   Reply With Quote
Old 03-01-2015, 10:41 AM   #15
Jim34RL's Avatar
I do not use the air pressure method until I have established a baseline on the stock truck ride height.
First put 10 LBS of air pressure in the bags; on a level roadway measure the height of the bottom of the wheel opening or top of bumper. Something that can be easily measured.
Now hook up trailer place enough air into the bags until achieve this same measurement you now have enough air pressure in the bags to ride level. See if this rides acceptable to you if not adjust either +/- 5 PSI in the bags maybe 10 PSI will do the trick. Recorded this air pressure reading and than you can reuse the air pressure that worked for you.
This has always worked for me and I still do this with every new trailer that I tow.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 03-01-2015, 11:18 AM   #16
Salt Shaker's Avatar
5 empty. 15-30 depending in road conditions. Usually around 20 is my sweet spot and 10-15 has my rig level.
I would start at a flat spot and then level make note of the pressure and adjust from there for comfort.
I would suspect (like me) you aren't going to need much with your set up.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 03-04-2015, 11:14 PM   #17
jjgabe's Avatar
I started with 30. That is where I was level. I tried 35, and 40. 35 seemed to be my sweet spot. I immediately noticed the difference. I think I need to get a longer shank though. With the truck level the trailer was now sitting slightly tongue high, I like it to be a little tongue low.
Old 03-05-2015, 12:09 AM   #18
just put airlift 5000 on my f150 in November and run em' empty unloaded and about 20 or so with trailer.
Might have to lower my draw bar head back down because as jjgabe stated I noticed that now my tongue is a bit high but the ride is great!
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 03-16-2015, 12:06 PM   #19
Kash76's Avatar
I measured the height of my TV without load and then put the tongue on and raised the truck back close to the original truck height. I use the Airlift 5000 and have 50 psi for pulling. Nobody else seems to have it that high :-/
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 03-16-2015, 12:11 PM   #20
lgray's Avatar
I run 45-50 when towing fifth wheel, approximatly 3,000 pin.
lgray is offline   Reply With Quote
pressure
