Old 09-05-2012, 12:53 PM   #1
Air bag question
I installed a set of Firestone air bags in my 2012 Toyota Tundra and when I go camping for the weekend I set the bags at 40psi and when I get home after a weekend trip the bags are down at 25psi. Is this normal to lose air when loaded?? I also set my air bags to 40psi with the trailer on the truck, should I be doing this before or after the trailer is on?
I did not get the compressor setup with mine, I just have the fill valves in the rear licence plate.
CalgaryCamper is offline   Reply With Quote
Old 09-05-2012, 12:58 PM   #2
TURBS's Avatar
Not normal ! You have an air leak.
You have to play with air pressure to fit your needs.
If you put 40 psi in unloaded you will get a higher reading loaded.
Example
If you put 40 psi unloaded you could have 60 or 70 psi loaded.
You just have to find right psi when loaded that is comfortable and sits vehicle and tt right
Ron
Old 09-05-2012, 01:01 PM   #3
Example
Ron
I think OP said he had 40# loaded and 25# unloaded which is normal.
If he had 40# loaded and 25# loaded on the return trip, then YES, he has a leak.
Old 09-05-2012, 01:23 PM   #4
TURBS's Avatar
Guess we need clarification
Old 09-05-2012, 01:47 PM   #5
wfmdfm's Avatar
I keep mine at 5 PSI unloaded. I measured the distance from the ground to the wheel well and recorded it. Connected the trailer and pumped till I was at the same measured distance on each side. It took 60 PSI to get to that point. Yes it also seems like you have a leak. Splash some soapy water on the fitting and you should find it.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 09-05-2012, 02:15 PM   #6
They are at 40# loaded and when I disconnected the truck from the trailer and went to air them down to 7# I noticed they were at 25# unloaded
Old 09-05-2012, 02:22 PM   #7
That would be normal. When I am hooked up, I run 65# and when I unhook, they will read 50# or a little less.
Old 09-05-2012, 07:55 PM   #8
RPAspey's Avatar
x2 normal.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 09-05-2012, 07:56 PM   #9
TURBS's Avatar
Your all good !
Old 09-05-2012, 08:24 PM   #10
Thanks everyone, was a little nervous
