Old 07-12-2012, 01:35 AM   #1
Air bags 2011 Ram 1500
Has anyone had any experience with airbags on a 2011 ram 1500.What kind of pressure are you running.Pulling a 2004 wildcat 28 rks.5 th wheel.Trailer bounces off hitch when road is rough.Currently pressure is at 14 psi.Any help would be appreciated.
Thanks in advance
daisy is offline   Reply With Quote
Old 07-12-2012, 06:39 AM   #2
TURBS's Avatar
Thanks in advance
I asked this same question.
Between 45 to 55 seems to be the average.
I run 50
Play around with them see what works best for you.
Old 07-12-2012, 06:59 AM   #3
Dave_Monica's Avatar
I used to run 30 psi in our Ram 1500 when we towed with it. You need to put enough pressure in them for the truck to set reasonably level.
Dave
Old 07-12-2012, 07:27 AM   #4
Rugged Brown's Avatar
If you haven't already installed airbags, have a look at Timbrens. Install and forget. Works on the same principle as airbags without the additional cost, install difficulties and ongoing monitoring and maintenance.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-12-2012, 07:45 AM   #5
racer30's Avatar
I have "airlift" brand and the most pressure is 45 lbs as per instruction booklet I received when I bought them. I currently am running 22 lbs and it seems to have taken the bounce out nicely. I had them at 45 and think it was taken over for the weight distrubution putting to much weight to the rear wheels....
2011 32ckds Shasta Revere
2009 Dodge Ram 1500slt
Moncton New Brunswick Canada
2012 NIGHTS CAMPED 43
racer30 is offline   Reply With Quote
Old 07-12-2012, 07:51 AM   #6
TURBS's Avatar
My air lift brand said Max pressure 100 psi.
Minimum 20 psi.
Old 07-12-2012, 08:12 AM   #7
racer30's Avatar
must be different lift capacities....mine are good for 1000lbs of lift.....
Old 07-12-2012, 10:27 AM   #8
The Ram 2011 1500 has coil rear springs.The max. psi is 35 on the Firestone Air Bags
Old 07-12-2012, 10:30 AM   #9
TURBS's Avatar
Are those bags inside the coil spring?
Old 07-12-2012, 01:37 PM   #10
Brigitte
boubou's Avatar
Thanks in advance
How are they working out to level your Ram?
I was told airbags wouldn't be enough to prevent sag on the Ram coil spring. Thought that was strange. The car add-on type of shop said timbrens where the better application for the Ram and I like the no fuss, no maintenance idea. I'll find out tonight when I hitch up and report. If not enough,then may be adding airlift as well (hopefully not necessary).
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
500, air bags
