Old 05-12-2014, 03:03 PM   #1
Forbes's Avatar
Air Bags & 5th Hitchs on Ford F350
If you are putting air bags and 5th wheel hitch on Ford F250 or F350 make sure you put the air bags on first if using a custom bed rail kit. The brace for the 5th wheel hitch covers the holding bracket mounting hole after installed, air bags first. Lesson learn hard way, had to remove custom brace in order to install air bag.
Forbes is offline   Reply With Quote
Old 05-12-2014, 03:13 PM   #2
Todouble's Avatar
I did hitch first on mine then airbags. Didn't have to take custom bracket back off but it did have to take the large bolt in center back out. Killed me getting it torqued to spec which was like 215 ft/lbs and then finding out I had to do it again.
Todouble is offline   Reply With Quote
Old 05-13-2014, 04:12 PM   #3
golfmedik's Avatar
I had to take the side plates of my B&W hitches on both my '10 F350 and my '13 F350 to get the airbag bracket bolts in too. A bit of an inconvenience but all it took is retorquing the bolts. The bags were well worth the trouble!!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
air bags, f350, hitch
