Old 09-05-2014, 10:17 AM   #31
Love my Firestone airbags!!! Took all the bounce out of our F150 when towing. I use a bicycle pump with built in air gauge. 12 pumps each and done. 10k miles this year and very happy. Found 35psi to work well. Too much air EQ hitch isnt doing its job.
Forest Road is offline   Reply With Quote
Old 09-23-2014, 03:36 PM   #32
Gustavomontoya's Avatar
Use to pull with a Tundra, installed airbags and it was great, problem is when your not towing it feels like you need a chiropractor after each speed bump
Gustavomontoya is offline   Reply With Quote
Old 09-23-2014, 04:03 PM   #33
Let them down to 5# when not towing and you won't know they are on the truck.
Old 09-23-2014, 04:27 PM   #34
We carry a $40 bicycle air pump w psi gauge. Fills bags in 10-15 pumps.
Old 09-23-2014, 04:57 PM   #35
Well OldCoot I resolved that problem by buying a 2500HD, thanks buddy
Old 09-23-2014, 05:09 PM   #36
Dazed & Confused
M&K Hoffman's Avatar
I have LoadLifter 5000 Ultimate on my Tundra. Run 7 psi when not towing and the ride is as stock.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-23-2014, 06:10 PM   #37
hey i fitted Firestone air bags to my ford F250 dual cab which helped however it did not arrest the front to rear 5th wheel movement, i changed the pin box to a Trailair which has its own airbag and a shock absorber i set the pressure at 60psi that worked a treat with my Flagstaff
Trevor Williamson is offline   Reply With Quote
Old 09-23-2014, 06:14 PM   #38
Wow. I tried everything and it was stiff
Old 09-23-2014, 06:42 PM   #39
i also should have added i set vehicle airbags at 20psi this keeps the unit level on the turntable
Old 09-23-2014, 07:21 PM   #40
rracer5's Avatar
Hey guys, those of you who have installed AirLift 5000's, recheck your documentation on the minimum PSI to run in the bags. I could be wrong but, I thought mine said NOT to run below 10 psi.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
air bags
