Old 08-20-2014, 06:20 PM   #21
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by OldCoot View Post
Air bags let YOU control the amount of assistance you want, which IMO is far superior to the Timbrens which only give you what they deem necessary.
x2000!
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-20-2014, 06:30 PM   #22
Originally Posted by Rugged Brown View Post
It is true that you can control the amount of assistance you want, however , my experience is that you either have them inflated full when trailer is hooked up or completed deflated with no trailer. Some will say 60 - 80 psi with trailer and 0-5 psi with no trailer depending on your weight and the ride you want to achieve. The point I'm getting at is that they are either engaged or not, which is the same as Timbrens, which IMO makes them operate the same...
As you say, you speak from your experience which is not how I use mine. I adjust the pressure according to the load. No load = 5#-15#, Load = 45#-65# and on a very few occasions 100#. Contrary to your statement, the airbags are constantly engaged, just to varying degrees unlike the Timbrens. Tire pressures are adjusted also. BTW, I have an onboard compressor which is 14 yrs old as are the airbags and no problems.
So, bottom line, if OP wants to control the ride, use airbags.
Old 08-20-2014, 06:54 PM   #23
PhoneDude 8289's Avatar
I am running with the Firestone air bags, no compressor, 40# towing and 5 - 10# daily driving. Also have bilstein 5100 shocks. Only added air to the bags one time while on the road, my little 12v compressor does just fine tho an onboard would be nice
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 08-20-2014, 07:10 PM   #24
Camper Less Camping
I do the same with my stinking diesel
Old 08-20-2014, 07:50 PM   #25
Don't have experience with add-on air bags, but did install Timbrens last week. So far they have met my expectations of leaving unloaded ride the same and significantly (by over 2") reducing rear end sag on my 2013 Ram 1500 and doing so at a very reasonable price.
I do have experience with factory airbags on my former 04 gmc envoy Denali XL. It had auto leveling system, which became problematic at about 6 years old and remained so until I traded it in for the Ram. Probably apples to oranges, but it was a factor in my decision to go with the lower tech Timbrens.
Brian
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 08-20-2014, 08:02 PM   #26
Brian
We've had 3 Caddys with the auto leveling system and it was air shocks, not air bags. I do know from experience, that there is a world of difference from the air shocks and air bags. Also had 2 El Caminos with air shocks. The present air bags were on my 2000 Silverado. Just changed brackets and installed on the 05. I like both systems.
Old 08-21-2014, 09:15 AM   #27
If the Timbrens end up not working out long term, good to know I can have confidence in the reliability of add on bags vs the factory bags that were such a headache. Thanks for the clarification.
ProPride Hitch
Old 08-22-2014, 01:13 PM   #28
Rick32040's Avatar
Just got my bags on today. Hope to see the difference in the ride with them on the next outing. Air lift 5000's.
2015 Primetime Crusader 295 RST TE
Chevy Silverado HD 6.0
Rick32040 is offline   Reply With Quote
Old 08-22-2014, 01:30 PM   #29
Camper Less Camping
Old 09-01-2014, 04:00 AM   #30
Just a member
kandl's Avatar
Timbrens and... air bags. Installed the Timbrens and was pleased with the performance but they still had trouble with them nasty prairie, frost heaved highways. Installed a set of Airlift 1000 bags shortly thereafter (left the Timbrens in) and the improvement was just short of exceptional. To be fair I should pull the Timbrens and reinstall the factory bump stops and do some comparison testing but it does appear that (Ram 1500 application) the two systems complement each other.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 09-05-2014, 10:17 AM   #31
Love my Firestone airbags!!! Took all the bounce out of our F150 when towing. I use a bicycle pump with built in air gauge. 12 pumps each and done. 10k miles this year and very happy. Found 35psi to work well. Too much air EQ hitch isnt doing its job.
Forest Road is offline   Reply With Quote
Old 09-23-2014, 03:36 PM   #32
Gustavomontoya's Avatar
Use to pull with a Tundra, installed airbags and it was great, problem is when your not towing it feels like you need a chiropractor after each speed bump
Gustavomontoya is offline   Reply With Quote
Old 09-23-2014, 04:03 PM   #33
Let them down to 5# when not towing and you won't know they are on the truck.
Old 09-23-2014, 04:27 PM   #34
We carry a $40 bicycle air pump w psi gauge. Fills bags in 10-15 pumps.
Old 09-23-2014, 04:57 PM   #35
Well OldCoot I resolved that problem by buying a 2500HD, thanks buddy
Old 09-23-2014, 05:09 PM   #36
Dazed & Confused
M&K Hoffman's Avatar
I have LoadLifter 5000 Ultimate on my Tundra. Run 7 psi when not towing and the ride is as stock.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 09-23-2014, 06:10 PM   #37
hey i fitted Firestone air bags to my ford F250 dual cab which helped however it did not arrest the front to rear 5th wheel movement, i changed the pin box to a Trailair which has its own airbag and a shock absorber i set the pressure at 60psi that worked a treat with my Flagstaff
Trevor Williamson is offline   Reply With Quote
Old 09-23-2014, 06:14 PM   #38
Wow. I tried everything and it was stiff
Old 09-23-2014, 06:42 PM   #39
i also should have added i set vehicle airbags at 20psi this keeps the unit level on the turntable
Old 09-23-2014, 07:21 PM   #40
rracer5's Avatar
Hey guys, those of you who have installed AirLift 5000's, recheck your documentation on the minimum PSI to run in the bags. I could be wrong but, I thought mine said NOT to run below 10 psi.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
air bags
