Old 12-26-2016, 11:20 PM   #1
Air bags on a 2016 2500 duramax?
Wondering if I should install airbags on a 2500hd duramax. My first instinct says no but the first trip of the new year is 9 hrs one way and I don't want to find out the hard way. I'm pulling a Flagstaff 8528 IKWS. The pin weight should be about 1,400 lbs
pd2020 is offline   Reply With Quote
Old 12-26-2016, 11:22 PM   #2
Oklahoma Proud
MillerTime's Avatar
Nope, you should be fine. Probably won't even bring the back all the way down to level
Old 12-26-2016, 11:27 PM   #3
Old 12-27-2016, 12:51 AM   #4
Not sure how much leveling you will need but the airbag setup will definitely give you more lateral stability.
BIRDS AREN’T REAL
Old 12-27-2016, 08:29 AM   #5
That was my thoughts and reason for asking (stability). I originally started towing this fifth with a half ton chevy that I installed timbrin on and it handled perfectly. A friend had a 1 ton towing a 32' fifth and he needed air bags to make the ride more stable. I understand there could have been a lot of different factors for him but it has me thinking. I hate to spend $500 if I don't need it
Old 12-27-2016, 08:35 AM   #6
dcheatwood's Avatar
No. You shouldn't need it with that pin weight. In my opinion.
2018 Forester 3011 DS
Old 12-27-2016, 09:24 AM   #7
Oklahoma Proud
MillerTime's Avatar
My old chevy 2500 did fine with the 1900lb pin weight of my 5er. Definitely felt strong side wind (like 20-30mph side winds). You are a lot lighter and your 5er is a lot shorter too probably so you won't have as much side force.
Old 12-27-2016, 01:24 PM   #8
Have same trailer with Ram 2500. Truck lowers very little , very stable towing.
Just check axle weights, if you have a 4X4 nose will be high putting more weight on rear axle.
randygk is offline   Reply With Quote
Old 12-27-2016, 02:17 PM   #9
My last TV was a gasser 2500 HD 2012 and I installed rear airbags and was glad I did.
offduty11 is offline   Reply With Quote
Old 12-27-2016, 02:37 PM   #10
jtesta1's Avatar
I have had air ride on my 2009 2500hd for two years now. I don't know if I needed it for the weight factor but it sure makes a difference in the ride . you can pick one up through Amazon.com for around 300. Easy to install.
jtesta1 is offline   Reply With Quote
Old 12-27-2016, 02:45 PM   #11
Airbags
Running Firestone Airbags on my 2500 HD. Made a big difference in the ride with the 5th wheel on however it did not take all the pogo sticking and chucking out. It helped but doesn't eliminate it. You will have to get a different king pin setup. I can't afford going that route so I just get off the gas and ride it out!!
MacDaddy is offline   Reply With Quote
Old 12-27-2016, 03:14 PM   #12
WFD
I have been towing the sister trailer to yours in the Rockwood line for the last 3 yrs with an 11 2500HD gasser, and no issues at all. We have since traded trucks and have the 16 2500HD Duramax now and do not plan on adding airbags, with past experience, can't see that we will need it. I would do without and this trip will give a very good indication. I highly doubt that this longer trip will cause you great concern to wish you had installed them prior to the trip.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-27-2016, 04:08 PM   #13
AquaMan's Avatar
I put 2300 lbs on my '11 2500 and just brought it to level. Added airbags after a year, but didn't like it aired up very high. Kept about 30lbs in when towing. Switched to a '13 3500 dually and had to add weight to the truck to get a decent ride.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 12-27-2016, 04:20 PM   #14
DDC
DDC's Avatar
I have 2015 and tow a cedar creek silverback 33IK, when I drop the trailer on it levels out, it tows just fine and I have zero stability problems.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 12-27-2016, 04:59 PM   #15
Thanks everyone for the replies and not to hijack my own thread but as far as the pogo sticking and chucking I purchased a Hensley Trailer Saver air bag hitch and I do like it. It takes about 90% of the bounce out. The nice thing is if I sell the trailer I still have the airbag hitch.
Old 12-27-2016, 05:28 PM   #16
keeprr's Avatar
I have a 2015 2500 Duramax. My fifth wheel has an empty pin weight of 1425. Pulled the rig 3500 miles from OKC to Virginia Beach and back. Only annoying thing about the combination is that there isn't enough pin weight to lower the rear of the truck. 6er rides a little high in the front and I have to unhook every night as there is no way to get close to level hooked up.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 12-27-2016, 07:12 PM   #17
Have an 03 Duramax and Air Lift airbag system. Tow a '17 Crusader, but put on the airbags with my old Montana. Had a big effect on the bumps and bounce in the truck, but getting the trailer to ride better is the ticket. My new Crusader is a much smoother ride even though the Montana had shocks. Sounds like you made a good move on the hitch, I've never wanted to spend the money on the expensive hitches, but I'm sure they help. Sounds like the combination of hitch and airbags and you'd be riding on velvet.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 12-29-2016, 08:19 AM   #18
muddyrode's Avatar
i put air bags on my 2012 2500hd with pin weight right at 2000#
it helped alot in the crosswinds by just running 20 pounds of air
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 12-29-2016, 07:19 PM   #19
Try drop shackles for the rear or scholastics.
340xlr is offline   Reply With Quote
Old 12-29-2016, 07:40 PM   #20
Frog-Toberfest Organizer
2015 2500 HD here and no air bags. I had air bags on my 1999.5 F250 7.3l and the ride seems to be about the same. Both have bounce and chucking in the same spots around here so the airbags didn't do me any good. I may eventually put some on but right now they are not an expense I need.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
Electra glide is offline   Reply With Quote
500, air bags
