Old 01-10-2013, 02:32 PM   #1
Air Bags on TV
Just put a set of air bags on my older F250, aired them up, and everything seems good to go. The front leaf springs on the old girl were just too darn rough, not to mention the rear! Hopefully the air bags will soften the ride a bit, as well as get the rear end back up.
I was just curious what kind of pressures I should be running.
Those who have done a similar install, what pressures do you run?
TIA
bakken is offline   Reply With Quote
Old 01-10-2013, 02:40 PM   #2
TURBS's Avatar
TIA
It really depends on your preference.
I run mine at anywhere from 50 to 70 depending on the roads I know I'll be on.
Some like it softer.
Turbs
Old 01-10-2013, 03:01 PM   #3
rotorhead1250's Avatar
Like Turbs said, it depends on how much you have in the bed or tongue weight your connecting. I run about 60 psi with my TT and a quad in the bed, as an example. Nothing exact, just getting it back to a level ride. When im empty, I leave about 5 psi in there per the Firestone rule book.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 01-10-2013, 04:58 PM   #4
Thanks guys.
I was just looking for some ballpark figures.
Just checking for leaks, I put 50 psi in the back and that raised it up over an inch. Then I put 40 psi in the front, and that diesel is so heavy it only went up a quarter inch!
It will be interesting once I get the camper dropped on it.
Thanks again for the feedback.
Old 01-10-2013, 05:44 PM   #5
Herk7769's Avatar
Just remember the bags won't make weak springs support like new.
If the truck has sentimental value, a new set of springs and a coat of wax might be a great present to an old friend.
HAM CALLSIGN - KC3FFW
Old 01-11-2013, 07:20 AM   #6
Yes Herk, she is an old and reliable friend.
But the springs don't seem that tired, as it only drops about an inch when I drop the 1500 lbs of camper on the hitch.
The air bags are mostly just for comfort, as it really does ride 'like a wagon' when empty. The older Fords with the leaf springs are great tow vehicles, but they were definitely not made for comfort!
I keep thinking about a new TV, but with only 120,000 miles on this truck, it is only just broke in! And other than the ride, the captain's chairs are more comfortable than the seats in most new trucks, and that old 7.3 pulls like a bear.
But we still have 3 months of winter to get through before I can even think about our first camping trip. I cant wait to see how much better it rides with the air bags.
Old 01-12-2013, 09:26 AM   #7
Smile
TIA
I'm about to put some air bags on my truck as well, firestone air rides. Which airbags did you buy and how long did it take you to install, thanks.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 01-12-2013, 09:47 AM   #8
jevanb's Avatar
buddy at work installed bags on his 99SD 7.3 and with his heavy slide in camper he is loving them, I am getting ready to pull the trigger for my TV, do not really need them but want a little extra lift
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 01-13-2013, 09:47 AM   #9
golfmedik's Avatar
I put Firestone's on mine....and I have a dually! Did I need them, not until after I had them What I mean is, they make the truck and camper much more stable. Even for the dually. I didn't realize how much bounce and sway there was without them. The ride is much more comfortable with a load. Really makes those trips on other states interstates much more relaxing! Make sure you plumb them independently. They are a great addition to any tow vehicle in my opinion. My wife was very skeptical, even questioning the money spent(not harping-just questioning). So on our first trip down the interstate, I aired down the bags and let the truck 'jerk and rebound' and then aired them up to around 45 pounds(5th wheel/3k in weight) so she could see the difference. She offered to pay for them! Good luck and happy towing/camping!!!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 01-13-2013, 11:00 AM   #10
mike06081969's Avatar
I had a set of Ride-Rites installed on my F-250 and they make all the difference in the world in ride comfort, handling, and stability. My 40' Blue Ridge 5er has a hitch weight of 1,930 lbs. I usually run 60 psi in the rear bags when towing, sometimes a little more or a little less depending on the road. I keep 10 psi in them when I don't have a load. (I don't have front bags.)
Mike in Tennessee
Former 2 time FR owner
2007 Crossroads Cruiser 30QB Fifth Wheel
2008 F-250 Lariat 4x4 6.4 Powerstroke
Firestone Ride-Rites w/cab control
mike06081969 is offline   Reply With Quote
air bags
