Originally Posted by scocope
What shocks did you end up putting on trailer. Never thought about that but makes sense
In our case I decided on Monroe gas shocks. They come in different lengths. Theshockwarehouse has good info. on installation, part numbers and prices.
https://www.shockwarehouse.com/news/rb511-in-stock.cfmhttps://www.shockwarehouse.com/site/mon_retrokit.cfmSomewhere, Monroe has a detailed diagram on how to mount them. You can get the Monroe shocks for $30 which isn't bad.
If you have 3" dia. axles, I'm not sure if the tie plate kit is available now. It wasn't when we bought the shocks. I used a stock tie plate and had a welding shop weld on a piece of DOM tubing for the bushing. It looks like the tie plate kit for 2 3/8" is available. For the upper bracket, I just got some flat 3/16" plate welded onto the side of the I-beam. The tie plate kit is in the photo. Our upper and lower mounts are in these photos. If your axles are over the springs, you only need one tie plate.
Our shocks are installed between the I-beam and wheel, exactly like OutdoorsRV does theirs. There are some other options to do it.
There are some other shocks/kits available like Mor/Ryde and LCI. Some don't require welding onto anything. If you need any welding, make sure to use a professional certified welder. The frame & axle shop that did ours at first (thanks to the dealer when we bought the TT) did a really poor job and one of the brackets actually peeled off the I-beam on a long trip and damaged a tire which had to be replaced. Went to another shop and had it all redone. The dealer paid for the redo and tire luckily.
