01-25-2016, 07:52 PM
#41
Air Lift 5000 air bags really do a great job of leveling our Excursion when we tow our 31 ft. XLR. I don't even use the bars on my weight distributing hitch anymore and couldn't ask for a better ride or tow. i love to tick the DW off by inflating the bags with the trailer unhooked. It makes her Excursion look like my Road Runner did back in the seventies when I would pump up the air shocks. I wonder if she would let me put some L70-15 tires on the Excursion like the Road Runner had? Nah, they couldn't handle the load.
01-25-2016, 07:56 PM
#42
Air bags (bought and installed by my son-in-law) were the best answer for leveling and traveling issues.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
01-30-2016, 03:13 PM
#43
I have both air bags and helper springs. They work great.
01-30-2016, 09:37 PM
#44
Wireless on board air and Firestone Airlift 5000 bags. Works like a charm.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
01-31-2016, 08:46 AM
#45
Looks like in your pic. you have two sets of springs? Which one is the helper springs and I don't see the air bags
01-31-2016, 09:09 AM
#46
The lower set of springs is the main leaf pack, the upper set is not really helper springs, but are factory overloads. Those 2 terms have become inter changeable now. What oems did was use 2 spring pack instead of one so when not towing/hauling heavy the ride was nicer. Then when towing/hauling the weight caused the second set of springs to contact the upper spring perches and act like one large spring pack.
The air bags are inside the spring right under the fram
01-31-2016, 09:16 AM
#47
And that's exactly what air bags AREN'T for.
I have the Airlift 5000 ultimates on my F350. Easy load leveling and no degradation in ride when empty. Even better now that I got the WirelessAIR compressor kit from Airlift installed. Very happy with the whole system.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
01-31-2016, 09:28 AM
#48
Thankyou for getting back to me
01-31-2016, 10:37 AM
#50
So my 12 Ram 2500 CTD has 2176lbs of payload capacity. If I add Firestone bags that add 5000lbs more weight carrying ability does that mean I can carry 7176lbs in the bed of the truck. My tires can handle 6830 lbs as I upgraded to some 18" 275/65/18 BFG KO2s. So I'm guessing my real limit would be the tires at 6830lbs does that seem right? With my empty rear axle weight of 2950lbs that means I could load 3880lbs in the rear. So the wife and I are light weights and total weight is around 270lbs, add in the 5th hitch of 175lbs that would leave us with a 3435lbs for pin weight. So realistically a pin of 3000lbs would be feasible.
01-31-2016, 10:48 AM
#51
Done with this
You're kidding, right?
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
01-31-2016, 10:56 AM
#52
Is this meant to be funny - At least I hope so!!! Air bags add zero to the max payload of what the truck can carry. You would exceed you MAX AXLE weight by hundreds of pounds with the numbers you are posting and you should never exceed max axle weights and put your love ones in the truck.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
01-31-2016, 11:06 AM
#53
5000 lb air bags mean they can support 5000 lbs without popping! They add no capacity to your vehicle.
Wallace
01-31-2016, 12:33 PM
#54
Air bags only assist in what your GVW is. Any upgrades to tires will only assist with what your GVW is. Neither adds TV GVW capacity as stipulated on your 2500 CTD door plate. If you have the "opportunity" to go across a weight station scale, that's the numbers they will hold you to.
DOT officers have been known to sit at state border crossings doing random checks. Their primary duty is trucks, but their ultimate duty is to keep the roads safe. It can get pretty pricey and inconvenient to be over the max GVW. These officers have a job to do and they can pretty well compute in their heads if the rig will pass muster. And rest assured, if you had an accident the GVW will come into play. If nothing else, think about the most precious cargo sitting next to you.
As the GPS says when missing a direction, "Recalculating-recalculating"
01-31-2016, 02:09 PM
#55
The top ones are the helper springs. There is the air bags crappy pics.
01-31-2016, 02:14 PM
#56
And as stated the bottom is the factory 2500 leaf springs. And in fact the top ones are helper springs. I installed them. And the bags..
01-31-2016, 03:32 PM
#57
I run airbags on my truck, not because I over load it but to level the truck back out when it is loaded. I have a small 3" lift installed in my truck and it sits level with nothing in the bed, but even with a 550lb ATV in the bed it squats noticeably (about 1.25"). With the 900 lb TW of the camper (with Reese dual), and a couple hundred lbs of firewood and misc in the bed it is very noticeable with the rear down about 3.5". But if the truck had the stock rake (front end down, rear end up) the rear would only be 1/2" low.
Mine has 5000lb Firestone Ride-Rite bags with a Airlift Quick Shot air system. With 35 lbs of air in the bags (and WD hitch on) the truck is back to level.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
01-31-2016, 04:11 PM
#58
Who Dares, Wins
That is the down side to many lifts.. They fail to mention that you loose your hauling ability a lot of times because the new Springs do are not made to do anything but lift a vehicle.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
