Old 01-21-2016, 01:44 PM   #31
I have installed Ride-Rite air bags on a Dodge Ram, GMC Sierra, and a Silverado over the past 10 years. Unassisted, I have never had to take off a wheel or jack up the vehicle. I had to remove the joust bumpers because that's where the bags attached. It took longer to find my tools and route the air lines to the rear bumper than it did to install the bags. I will concede it took longer than 10 minutes, No need to take on/off. Super Springs vs Ride-Rite is about a wash in dollars on a quick check. The bag sets we bought for each of the 3 vehicles was under $300 on sale.
Porpoising and sway have not been a problem with the Lance slide in on the Ram, and towing some pretty hefty loads and stiff cross winds (our last trip was 40 mph cross winds) with the Sierra and Silverado. No matter if you use springs or bags, the weight still ends up on the axle. The bags work in concert with the springs rather than instead of.
PenJoe is offline   Reply With Quote
Old 01-21-2016, 04:15 PM   #32
The Big Toe's Avatar
Yuh, porpoising.
Sometimes, my brain just lets me down
The Big Toe is offline   Reply With Quote
Old 01-21-2016, 04:17 PM   #33
Usually Confused Member
emm-dee's Avatar
That highlighted statement sums it all up.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-22-2016, 05:44 AM   #34
Originally Posted by Homebrew View Post
Air bags have issues in a few years, springs are forever.
Air bags and springs don't make your truck carry more.
Have used mind now for 7+ years, still going strong.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 01-22-2016, 06:34 PM   #35
Homebrew's Avatar
The local installer told a couple Ford friends that the springs are better and less aggravation if not full time towing. They both said he mentioned air bags cracking if not exercised frequently. Maybe it's a brand thing, maybe it's a newer model thing. I do know rubber and compressors fail. Steel spring normally last as long as you have a truck.
Adding springs was less expensive than adding air bags.
As with all items the older stuff worked, the newer stuff is crap.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-22-2016, 06:56 PM   #36
emm-dee's Avatar
I don't know about other brands but the AirLift springs have a lifetime warranty.
Old 01-23-2016, 07:46 AM   #37
Who Dares, Wins
doc73's Avatar
Like I said.. Used my Airlift on a lifted Jeep rock-crawler then pulled a popup for years... If I did not break em they must be good... And I've broke some stuff! LOL
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-23-2016, 08:10 AM   #38
Not sure what basis this installer is using. Air bags cracking if not used frequently sounds more like muscle atrophy. Normally, UV is the biggest enemy of rubber and bags are not exposed to direct UV as are tires. Springs are subject to constant load and rust-and they also have some rubber components. Nothing is forever.
Old 01-23-2016, 09:16 AM   #39
muddyrode's Avatar
If you were to tye both air bags to the same air line you would still get body roll as the air would travel between the air bags, but if you have seperate lines to each air bag you will greatly improve the body roll
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 01-23-2016, 03:04 PM   #40
Muddyroad, that makes perfect sense. Thank heavens I have done separate lines.
air bags
