Old 08-02-2016, 07:40 PM   #21
Originally Posted by MT Biker View Post
That's the same one I got. Fits in my empty generator compartment or my pass through storeage on a Wildcat 29rlx. Since I don't have a generator I check my tires in the campground. I do have a 110 outlet in my truck (2015 Ram 3500), but I don't know if it will run the compressor.
Steve29rlx is offline   Reply With Quote
Old 08-02-2016, 09:48 PM   #22
I carry two Honda's so I can pump up a tire if I have too
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-02-2016, 10:35 PM   #23
SailorSam20500's Avatar
I took a look at the compressor specs on the P/C web site. Specs say it pulls 10 amps. Does your truck push 1000 watts? My Ford has a 400 watt limit...
Al
S.E. Mich.
Flagstaff 26FKWS / 2016 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 08-02-2016, 10:48 PM   #24
trbomax's Avatar
I have the harbor fright 150 psi pancake unit.It is attached to a 50' hose reel.50' of hose will reach any part of our rig.
trbomax is offline   Reply With Quote
Old 08-02-2016, 10:51 PM   #25
trbomax's Avatar
here it is,it missed the upload first time!
Old 08-02-2016, 11:03 PM   #26
I don't think it pulls 10 amps. I looked a couple of these up and at least one of them said "AMP Capacity = 10amps." I have no idea what "AMP Capacity means."
I have two similar compressors, a Campbell Heuser like this one:
And a Fini like this one:
The CH says it pulls 2 amps and the Fini says 1.8 amps.
So I strongly suspect the Porter-Cable one pulls about 2 amps, not 10 amps.
However, 2 amps at 120 VAC is 240 watts. Too much for the 150 watt inverter limit in my Silverado, but should be OK for your 400 watt unit.
2011 Traverse LT, 3.6L, FWD
Old 08-03-2016, 10:57 AM   #27
CWSWine's Avatar
I had low tire on my RV this spring and didn't want to move the 5er without putting air in it. I don't have power where I store my 5er so headed out to find a cheap 12volt compressor and found a Black and Decker for 50 bucks that was rated to 160 psi that was 12 Volt/120 Volt. I wasn't impressed with the 12 volt operation but worked but the next time I used it I used the 120 volt option and was impressed how well it worked. Not a bad deal for 50 bucks just to use to top off a tire.
https://www.amazon.com/dp/B000IE0YIQ...I2S59G5IS5YJM9
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-03-2016, 08:20 PM   #28
Crookedread
crookedread's Avatar
I have used a 120 volt Emglo for years to run my small finish nail guns. Works perfectly for tires and toys in our toy hauler.
crookedread is offline   Reply With Quote
Old 08-03-2016, 08:35 PM   #29
I mounted this under my truck and I have compressed air anywhere I go.
VIAIR Corporation - Ultra Duty Onboard Air System (P/N 20001)
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
tire, tires
