Old 01-10-2015, 09:54 PM   #21
Helmsey's Avatar
Before I had an on board system I used a bicycle pump...good ol hand pump that I had for the bikes. I was able take mine from 5 to 30ish pounds in just a few pumps.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 01-11-2015, 07:03 AM   #22
Stormrider151's Avatar
Originally Posted by mike.t View Post
Funny stuff.(The mechanic) So the system has a fill valve somewhere i assume.
I made a small L bracket for the air valve and bolted it under the bumper next to the trailer light plug.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 01-11-2015, 08:17 AM   #23
Shinny's Avatar
I love the one I mounted under my truck. It's wireless and easily controlled.
Amazon.com: Air Lift 25870 WirelessONE Compressor System: Automotive
It's this compressor, but I bought it from someone else and can't remember who.
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 01-11-2015, 08:45 AM   #24
Engineer of Crazy Train
ChooChooMan74's Avatar
I think that I will get that. I like the fact that it keeps the minimum 5psi in the bags. Last winter, with all the ice, snow, and cold, I lost my air bags due to no air. Went all last year without them. I got the new ones sitting, waiting to be installed. I think I will install it with this!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 01-11-2015, 09:05 AM   #25
f5moab's Avatar
Originally Posted by Mr. Dan View Post
I'm too cheap to buy the onboard compressor so I just use a $50 12v sLime compressor from Wal*Mart. I always carry it anyway.
What I currently use on my H3 and Silverado air bags, and have used it many times to inflate my H3 tires from 12 psi back to 35 psi after off-roading.
f5moab is offline   Reply With Quote
Old 01-11-2015, 09:06 AM   #26
f5moab's Avatar
Can you add a separate line for inflating tires too? Or is it dedicated to the bags only?
Old 01-11-2015, 10:14 AM   #27
I have had several trucks with air bags and found the onboard compressor to be by far the best way to go, I sometimes adjust the air to fit the road we are on, and it is so convenient to let the air back down after hauling a heavy load.
densal is offline   Reply With Quote
Old 01-11-2015, 12:29 PM   #28
Campingnut's Avatar
Originally Posted by Carrier View Post
Are you having any problems with fuse blowing when it is really cold out? I had to use a resettable circuit breaker as the fuse would pop if compressor came on especially this last few weeks. I mounted everything above the spare tire on my F150.
The only problem I have had is the Control valve went and it was replaced by Air ride, they know want an air dryer in line from compressor to control valve.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 01-11-2015, 02:39 PM   #29
dcheatwood's Avatar
I have the onboard compressor with wireless remote with my airlift system. Worked great for 2 years then the manifold went out. But the compressor is a simple little 125psi portable. I also keep a 3 gallon compressor in my fiver front end near the Schrader valves on rear truck bumper. And portable one under rear seat in truck. Anything will work if it can connect and has at least 80-100 psi. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 01-11-2015, 02:42 PM   #30
dcheatwood's Avatar
My onboard manifold went out so I'm looking to convert it to a manual switch with gauges in the cab. Is that what you have?
air bags
