01-10-2015, 10:54 PM
#21
Before I had an on board system I used a bicycle pump...good ol hand pump that I had for the bikes. I was able take mine from 5 to 30ish pounds in just a few pumps.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
01-11-2015, 08:03 AM
#22
Originally Posted by mike.t
Funny stuff.(The mechanic) So the system has a fill valve somewhere i assume.
I made a small L bracket for the air valve and bolted it under the bumper next to the trailer light plug.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
01-11-2015, 09:17 AM
#23
I love the one I mounted under my truck. It's wireless and easily controlled.
Amazon.com: Air Lift 25870 WirelessONE Compressor System: Automotive
It's this compressor, but I bought it from someone else and can't remember who.
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
01-11-2015, 09:45 AM
#24
Engineer of Crazy Train
Originally Posted by Shinny
I think that I will get that. I like the fact that it keeps the minimum 5psi in the bags. Last winter, with all the ice, snow, and cold, I lost my air bags due to no air. Went all last year without them. I got the new ones sitting, waiting to be installed. I think I will install it with this!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
01-11-2015, 10:05 AM
#25
Originally Posted by Mr. Dan
I'm too cheap to buy the onboard compressor so I just use a $50 12v sLime compressor from Wal*Mart. I always carry it anyway.
What I currently use on my H3 and Silverado air bags, and have used it many times to inflate my H3 tires from 12 psi back to 35 psi after off-roading.
01-11-2015, 10:06 AM
#26
Can you add a separate line for inflating tires too? Or is it dedicated to the bags only?
01-11-2015, 11:14 AM
#27
I have had several trucks with air bags and found the onboard compressor to be by far the best way to go, I sometimes adjust the air to fit the road we are on, and it is so convenient to let the air back down after hauling a heavy load.
01-11-2015, 01:29 PM
#28
Originally Posted by Carrier
Are you having any problems with fuse blowing when it is really cold out? I had to use a resettable circuit breaker as the fuse would pop if compressor came on especially this last few weeks. I mounted everything above the spare tire on my F150.
The only problem I have had is the Control valve went and it was replaced by Air ride, they know want an air dryer in line from compressor to control valve.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
01-11-2015, 03:39 PM
#29
I have the onboard compressor with wireless remote with my airlift system. Worked great for 2 years then the manifold went out. But the compressor is a simple little 125psi portable. I also keep a 3 gallon compressor in my fiver front end near the Schrader valves on rear truck bumper. And portable one under rear seat in truck. Anything will work if it can connect and has at least 80-100 psi. Good luck.
2018 Forester 3011 DS
01-11-2015, 03:42 PM
#30
My onboard manifold went out so I'm looking to convert it to a manual switch with gauges in the cab. Is that what you have?
01-11-2015, 04:15 PM
#31
Did you contact Air lift they might do something for you?
Tim and Bev
2020 F-350
01-11-2015, 07:23 PM
#32
I asked them about a drier back in October when I bought the 72000 and the guy I talked to at Air Lift on the phone didn't have a clue what I was talking about. I have been looking for an in line drier so if you do find one please pm me the information.
Since I put the 15 amp circuit breaker in it works much better.
Did Air Lift send you one direct from them or did you have to go through where you bought it from?
01-11-2015, 07:55 PM
#33
Yes. I was 2 mos out of warranty and they offered to rebuild it for $95 plus shipping. I tried to buy a new one. No longer available. Replaced by a new model. But it was worth it for those 2 years.
01-11-2015, 08:10 PM
#34
They sent the dryer with the control valve that was replaced by Air lift themselves.
Tim and Bev
2020 F-350
01-11-2015, 09:29 PM
#35
Did it cost you anything? I must have talked to a new guy or someone who really didn't care.
01-12-2015, 08:48 AM
#36
Would you believe I had to pay a deposit and shipping both ways, but in the end it was worth it. I wish I remembered the guys name.
Tim and Bev
2020 F-350
01-12-2015, 09:05 AM
#37
Originally Posted by scottsman411
What does anyone use to put air in their air bags? I would like to find a portable air compressor that will inflate my air bags at the campsite.
We have a 2011 F250 with 6.7 diesel that I have installed Firestone air ride on. I like to reduce the pressure after getting to the campsite so the ride is not so stiff while exploring then be able to inflate back up to move to next site.
With my F150 the Firestone bags mount above the spring center bolts. With this I have found that unless I have between 10 to 15 psi in the bags they bottom out. I believe that on your 250 they mount inboard of the springs and you probably don't get this but still need the minimum 5 psi that Firestone recommends.
I tried the manual method using a tire pump and portable compressor but it was always a pain in the butt. You will not be sorry to install either the Firestone or Airlift compressor. You just have to decide if you want a wireless or manual valve in cab.
I have had some issues with the Airlift 72000 wireless in the winter conditions here but do not regret installing an onboard compressor.
01-12-2015, 09:10 AM
#38
That doesn't surprise me. I am going to phone them again this week and see if I can get someone who knows what they are talking about.
#39
May I ask "what concerns?"
I'm in the process of purchasing a new Silverado and was looking at this system or the less expensive 25870.
When installed, did you or the installer add the X-number of ounces of Gunk Air Brake Deicer recommended by airlift? Talked with an installer here in ID and they add the deicer.
Main difference I can see between the two, is the 72000 has a larger, quieter compressor and can inflate each side separately to level side-to-side. Not sure if I need the side-to-side.
01-12-2015, 09:20 AM
#40
I always add air line antifreeze to mine before winter.
Tim and Bev
2020 F-350
