Old 06-17-2015, 10:51 PM   #1
Lon
Lon's Avatar
Air conditioning while towing
I've noticed my airconditioner seems to work less efficiently when I'm towing my mini lite tt uphill on a hot day. Is this a normal expected decreased function under these conditions or should I get it checked out. The unit works perfectly when the engine is not under extreme load.
Name:   ImageUploadedByForest River Forums1434599503.743977.jpg
Lon is offline   Reply With Quote
Old 06-17-2015, 11:00 PM   #2
deebarjay's Avatar
prolly something to expect....how are the truck temps? you have 2 maybe 3 radiators back of your grill coolant tranny and ac. going uphill especially on a long incline in a lower powered truck on a hot day...my guess.
deebarjay is offline   Reply With Quote
Old 06-18-2015, 12:56 AM   #3
SKnight's Avatar
You didn't give any manufacturer info, so I assume it's the Chevrolet in the picture? If so, yes, that's normal operation. When the engine computer sees certain parameters under load it turns off the AC compressor to free up some power, and that happens before you're on the floor.
Old 06-18-2015, 05:44 AM   #4
davel1971's Avatar
most any vehicle will turn the ac compressor off when you reach a certain point in the throttle or high RPMs. Nothing wrong at all.
David & Lynn
Old 06-18-2015, 12:25 PM   #5
Lon
Lon's Avatar
Thanks. U saved me a big mechanic bill!
Old 06-18-2015, 12:27 PM   #6
TURBS's Avatar
I agree "all normal"
Course a duramax a/c never shuts off with all that hp and torque available.
Ops did I say that?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-18-2015, 04:05 PM   #7
SKnight's Avatar
Ops did I say that?
TURBS
2011 32bhok Sabre
And you're likely right, because with the available power on tap you probably don't hit that mark very often for very long.
It varies by model and engine combo, but 85% power demand is kinda the mark where the compressor turns off. Note, power demand, not throttle position. It's an algorithm that takes into account throttle position, vehicle speed, engine speed, transmission gear along with other parameters.
So if you never need to hammer it, it'll never turn off.
Old 06-18-2015, 04:44 PM   #8
Lon
Lon's Avatar
Uh oh. I've had some problems with my throttle position sensor. Ur post reminded me. I'll bet that intermittent TPS problem is playing a role in this.
Old 06-19-2015, 07:56 AM   #9
A/C running warm
Attachment 80329
In most if not all cars/ tricks built today have a switch or preset in computer when in heavy throttle/ full throttle the a/c shuts down, it is presumed you need the power and it aids in cooling under heavy load conditions.
So your answer is YES this is normal
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-19-2015, 08:00 AM   #10
B and B's Avatar
Ops did I say that?
TURBS
2011 32bhok Sabre
Same with Super Duty!! It just gets colder!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
towing, air conditioner
