05-10-2013, 09:15 AM
#41
Before
After
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
05-10-2013, 09:17 AM
#42
Originally Posted by LaydBack
Before
After
Nice SABRE ! envious !
05-10-2013, 09:58 AM
#43
Nice stance on the rig now!
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
05-13-2013, 08:26 PM
#44
Ok, you air bag experts. Read the instructions and watched videos. What is the yellow thing called in the picture? Guess this is supposed to be removed but what does it actually do?
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
05-13-2013, 08:29 PM
#45
Bump stop.....yes you remove it.
LINK TO MY MODS
05-14-2013, 03:41 AM
#46
Yep! x2..bump stop has to go.....
05-14-2013, 06:46 AM
#47
Great guys, that's what I thought, thanks.
Mike
2012 Lacrosse 303RK
06-07-2013, 06:36 AM
#48
I just installed the air lift 5000 bags on my 2011 GMC 2500 hd. I was very meticulous and took my time routing the air lines, and the whole install took about 3 hours. I did not have to remove the rear wheels, and I am not sure it would have even helped...I worked around them to install the bags over the axle and most of the rest of the work is done underneath the truck.
I must say that everything fit perfectly...very high quality kit, good instructions, and no grinding or drilling (for non-5th wheel).
I filled the bags with 30 pounds (no compressor) and went for a ride...pretty dang rough empty. i have not had a chance to tow with it yet, but will be towing next weekend.
Anyway, I dropped them to 10 pounds the next day (let them sit over night and still had 30 pounds-no leaks...hurrah). Took a drive with 10 pounds and still rode pretty rough...jarred the heck out of me on rough roads.
Dropped the pressure to 5 pounds, and the jolts over harsh bumps were still way too hard to take. I tried 3 pounds and it was still an awful ride.
I know many folks say they ride good with 5-10 pounds of pressure, but it does not work on my truck....
I left all the air out and it rides like before the install, of course. I know they recommend 5 pounds of pressure, but I cannot see how the bags could be distorted or trashed. They just sit there. Actually, there is air in them, just no pressure. There is nothing for them to hit on, and I do not do any off-roading
I have read several posts on other forums where guys have run zero pressure without issues....guess we will see over time.
I am looking forward to towing the first time with them....will let you all know!
2014 Ram 1500 Quad Cab
4x4, 5.7 Hemi, 3.92, 8 Speed
2013 Forrest River Flagstaff
30' "V" Lite, 7300#
06-07-2013, 07:28 AM
#49
My install was equally as pleasant. I didn't remove my wheels or jack the truck up. We found 55psi to be good going down the road with the 5er, and I run 5psi when empty.
LINK TO MY MODS
06-07-2013, 07:57 AM
#50
I found my very easy. Never took the wheels off the truck. With installing the compressor and gauge it took about 2.5 hours including cleanup. I preassembled the bags prior. I run about 30 in mine all the time and about 50 towing. I also have a 2.5" leveling kit in the front of the dodge. Rides a lot better with the bags.
2008 Rockwood 8281ss
2006 Dodge Ram Mega Cab Hemi
Reese 15k Slider
06-07-2013, 08:10 AM
#51
What is your (True) ready to go down the road tongue weight? What type of W/D hitch are you using? What flagged your need for air bags. I have used air lift bags in the past,when unloaded they had 5-10psi. Youroo!!
06-07-2013, 10:21 AM
#52
My dually actually rides best at 12 psi. A buddy's F250 rides great at 20. His other truck rides best at 5 psi. Do a little playing with it. You may actually like 3-5 psi best. When loaded, play with it too. It may take a while to try the different settings, I would try them in 5 pound increments until you get it right. That is the main reason I went with an onboard compressor so I could adjust on the fly. I found this out after towing down a couple of different interstates with changing road conditions. Now, I can change the pressure as the road conditions change.
06-07-2013, 10:32 AM
#53
daydreaming about camping
Being that they are rubber, I would guess there is some break in.
My truck had them installed when I picked it up. They had 30 psi in them (mine has the Firestone kit with in cab controls and pressure gauge) and the ride was horrible. On the fly I dropped it to 20, got better...dropped it to 10, got better, dropped it to 0 and was better. Firestone recommends you keep 5psi in the bags so I inflated back to 5 psi and cannot tell a difference between that and 0. I have no way of knowing, but would estimate the bags have been on the truck several years.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
