Old 06-01-2016, 09:25 PM   #1
Question Air lifts on a trailer?
I have a 42Ft XLR towed with a Ram 3500 long box. I have hit the truck side rail while turning into a campground with a bad dip in the road causing damage to both units. There just is not enough clearance above the truck. I don't want to flip the axles and raise the hitch because the unit is high enough already, so I was thinking about installing air lifts on two of the axles so that I could raise the trailer higher when the going gets rough. Has anyone ever seen this done or have any comments?
RV- 2014 Thunderbolt XLR 386X12 Called "The Castle"
TV- 2013 Ram 3600 DRW Diesel Called "Hercules"
rick42wood is offline   Reply With Quote
Old 06-02-2016, 11:52 AM   #2
Head Rambler
Hydraulics would be better and you need to lift all three axles if you're going to do it.
I think you'd be better off having a custom bed made for the truck with lower side rails. Or even a flat bed with low storage boxes.
Gotta go campin!
Old 06-02-2016, 02:45 PM   #3
Custom truck box
I'll do that if I win a lottery.
Old 06-02-2016, 02:52 PM   #4
RollingDownTheHighway's Avatar
you can put air bags on the trailer and lower and raise them as you see fit. It'll also give the camper a smoother ride so your "toys" in the garage won't bounce around as much.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 06-02-2016, 03:17 PM   #5
Anybody out there that has actually done this?
Old 06-02-2016, 03:22 PM   #6
here is something
trailer
