Old 01-22-2017, 04:50 PM   #1
Air ride
Just bought a 2017 FR Wildcat 311RKS!!
I have a 2015 Ford F 150 XLT = 10,200 rating
Anti-sway system hitch rated at 10k
Wildcat= 6735+730 (hitch) + 2,795 (ccc) = 10,260
We travel lite=500 pds (150 just for my tools)= All in at about 8,000 for us.
Friend tells me to get a simple air ride for my truck to improve ride & safety= Firestone Ride-Rite Air Helper Springs...
Dealer says: The system isn't needed...
Unit is being built...I haven't pulled it yet...
Family has about an 800 mile trip planned. We camp a lot, but we don't pull the rv very often...= permanent spot at a campground...
Any opinions on your experience would be appreciated!!
Boss1 is offline   Reply With Quote
Old 01-22-2017, 07:14 PM   #2
I'm not familiar with the 150 suspension. But, air bags shouldn't hurt anything. You don't get increased weight carrying capacity and with a proper WD hitch you shouldn't need leveling. But, you will definitely get a big increase in stability. Everyone I know who has installed them mentions the reduction increase in lateral stability, even when not towing.
BIRDS AREN’T REAL
Old 01-22-2017, 07:24 PM   #3
Dmaster79's Avatar
I have the airlifts on my 2013 F150. Run about 30psi in them when towing my 26RR. Helped firm things up along with LT tires you can't go wrong.
Dmaster79 is offline   Reply With Quote
Old 01-22-2017, 08:10 PM   #4
I have firestone ride rite air bags wit LT tires. Helps a lot with any extra sag. I run about 40psi while towing. Provide much better handling. I have a 2002 f150.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 01-25-2017, 06:27 PM   #5
Tom
Seachaser186's Avatar
I am towing a similar setup, a Salem Hemisphere 282RKS and 2016 F-150 3.5 EB. This year I will be installing LT E load tires and upgrading to a Propride hitch. I was able to do it with the P tires and round bar WDH with friction sway controls but it was more white knuckle than I cared for. These trucks do have a sag issue when you hook up 900 lbs of tongue weight so I went with progressive helper springs.
Seachaser186 is offline   Reply With Quote
Old 01-27-2017, 07:14 PM   #6
thestrangebrew's Avatar
I'm running airlifts pulling a 2014 233s with my 2014 F150 EB. Also have an Andersen WDH. It's great combination IMO. I usually drive with 10-15 psi when not hooked up and about 30 psi when towing. Next up when OEM tires wear out will be LT tires. I don't think you can go wrong with airbags, just don't expect them to transfer any weight (not what it's supposed to do).
2022 F250
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 01-27-2017, 07:44 PM   #7
I installed Air Lifts in my 2014 Ram - coils just squat too much. Dont know about the Ford, but I'll tell ya - Wildwood 28RKSS (34 feet 7000#) doesn't wallow or sway and the ride is level.
Sawtooth is offline   Reply With Quote
Old 01-27-2017, 08:14 PM   #8
....and they last a long time too...
I installed the Firestone bag kit (with on board compressor) on my 1997 F350 in 1998 and they are still going strong.. no issues at all. Lets see, that is almost 20 years... Not a bad ROI in my opinion.
SidecarFlip is offline   Reply With Quote
Old 01-27-2017, 09:21 PM   #9
I put bags and on board compressor on my 06 f-250 and hope I get that long out of them.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
