Old 03-02-2012, 04:21 PM   #1
air shocks or air bags
hauling wildcat 5er with 09 dodge 1500 wildcat weight 8500 would air shocks or air bags help with the suspension
ypop is offline   Reply With Quote
Old 03-02-2012, 04:37 PM   #2
Rest and Relax's Avatar
Exclamation
Air bags will help your suspension but does not change your weight rating!
Rest and Relax is offline   Reply With Quote
Old 03-02-2012, 05:25 PM   #3
Yep that 5er loaded ready to roll is probably over your 1/2 ton trucks tow rating .The HEMI and transmission will pull it without an issue it's the trucks frame,suspension,axles,brakes that are being pushed beyond it's limits. Any of the true to form 1/2 ton towable 5er's are gonna be more in the 6700# area dry. As stated above airbags will help level the ride I have them in my Ram 1500. Another option is Timbrens wich are basically a heavy duty set of rubber stoppers in place of bags.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 03-02-2012, 06:05 PM   #4
In response to the actual question..they will both provide less squat....air bags are a more permanent non cheesy solution. Disclosure statement: do not exceed trucks ratings!
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 03-02-2012, 06:14 PM   #5
Campfire Master
Stay with the air bags. The shock mounts may not take the extra strain.
John
AVid is offline   Reply With Quote
Old 03-02-2012, 07:14 PM   #6
In my opinion air bags are much better option than the air shocks. They will definatley help your ride height.
rkswyo is offline   Reply With Quote
Old 03-02-2012, 07:39 PM   #7
bikendan's Avatar
neither will help if your Dodge is overloaded.
you haven't provided enough info.
what year and model is your Wildcat and is the 8500lbs. the fictional brochure "dry" weight or its actual factory sticker weight?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-04-2012, 09:43 PM   #8
MotocrossCamper's Avatar
Shock mounts are not designed to haul loads! Air shocks should be banned in my opinion.
MotocrossCamper is offline   Reply With Quote
Old 03-04-2012, 11:26 PM   #9
wneise's Avatar
A third (or maybe second with that last post) option should be helper springs. Most bolt on top of your current set of leafs and it is not to hard of a job for a do it your selfer.
wneise is offline   Reply With Quote
Old 03-05-2012, 12:36 AM   #10
Just a member
kandl's Avatar
N/A - the 09 Dodge half-tons are sprung with coils.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
air bags
