09-26-2013, 10:06 AM
Airbags
Anyone seen or heard of, or know if this exists? Was wanting an air bag kit with built in compressor that has a utility line so you can use the compressor for bike tires, rafts,TV tires etc.
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
09-26-2013, 10:10 AM
airlift, thats what I have and I can air up tires and my bags. you can put as many utility lines in you want, on the front bumper and back bumper or even in the bed
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
09-26-2013, 10:13 AM
Nice...thanks
2013 Days Camped 14
09-26-2013, 10:27 AM
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
09-26-2013, 10:28 AM
I already have air bags installed on my rig.
What I plan to do for a compressor is to install a 12v pump as well as a 2 gallon or so reservoir tank for it. Off of that I will plumb in a connection for a air hose to connect through the bumper of my truck...
I plan to have a short hose for filling my bags off of it as well as a longer one so i can fill truck tires, trailer tires, toys ect...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
09-26-2013, 11:58 AM
Now a "Top Member"
You don't need airbags to have the capability to air tires and such. There are a lot of options for that. But if you need, or want, airbags to help level your truck, then it can be advantageous to get the compressor with the airbags and then get an air reservoir tank as avolnek is suggesting. A typical compressor for airbags may not be sufficient to air truck or trailer tires, but would probably be fine for bike or even ATV tires. The tank would help tremendously for other vehicles. Any airbag kit can be made to accomodate a compressor and tank. It's just a matter of hooking it all in.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
09-26-2013, 07:47 PM
I installed a Viair 10007 Onboard Air System and love it. I can adjust the airbags on the fly and air up anything I need to. Here is the write up. http://www.forestriverforums.com/for...led-35846.html
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
09-26-2013, 10:11 PM
A wealth of info thank you!
2013 Days Camped 14
03-26-2014, 12:37 AM
Ok air bags installed....couple of questions.
1) In regards to setting up the wd hitch I wanted to confirm I need to level out the truck and trailer WITHOUT inflation correct?
2) utilizing the air bags to achieve unloaded rear height of truck or how much to inflate?
2013 Days Camped 14
03-26-2014, 05:42 AM
Installed airlift load lifter 5000, in 2009. Bags developed pinhole leaks this year. New ones being shipped right now under lifetime warranty. I have wireless air with onboard compressor with 120 psi rating. Can use it to pressurize anything with a hose to fit the Schrader valve in the rear bumper.
Sent from David's RAZR M.
2018 Forester 3011 DS
03-26-2014, 05:57 AM
Dependent on MFG of bags they have a (Min.PSI) requirement to maintain. When I used Bags I would (Hook up and then Air Up) to Level. Youroo!!
03-26-2014, 05:58 AM
Plain Old Member
We don't have the air bags, but do have a onboard compressor that serves 2 purposes right now; air chuck installed in the running board for uses that you mentioned, and the train horns. May add air bags later. It is indeed very nice. We have a 50' air hose in the truck, so I can adjust the trail air hitch, all tires on vehicle and fifth wheel, plus air up bike tires and toys. Wouldn't be without it.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
03-26-2014, 07:20 AM
Correct!
Setup the truck and trailer first, and use the air bags to assist the w/d hitch if needed! You may or may not need to depending on what you are hauling.
When I have just my trailer attached my w/d hitch does a fine job, but once I start adding things into the bed I begin to squat more and more. My reasoning for adding air bags was because I installed a leveling kit on my truck, so if the rear end squats more than a half inch it begins to go nose high.
Stay safe!
03-26-2014, 12:52 PM
Thanks for the replies!
2013 Days Camped 14
03-26-2014, 01:21 PM
here are the instructions straight from airlift...setup, airup, load truck air up more if necessary...
http://www.airliftcompany.com/worksh...s-air-springs/
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
03-28-2014, 06:41 PM
All very helpful thanks a million!
2013 Days Camped 14
