Old 03-29-2011, 09:12 PM   #1
Airbags or not
Hi all,
One more question and I will be set,
Do I really need Airbags for the following?
My Camper will be a PUMA-FBSS
Hitch dry weight - 705 lbs
Dry Axle weight - 5460
Total dry - 6165
Carrying cap - 4662
GVWR - 10,865
Lenght 29'9"
Height 11'1"
My TV is a 2005 F250 Lariat Super Duty Diesel with 35,000 miles:
Trailer Hitch Receiver 12.5K
3.73 ratio Limited slip
142" WB
Trailer towing package -
Suspension with Stablizer bar
Mono Beam Coil Spring
9800 GVWR#
So the questionis what benifits will adding airbags have? I'm looking at the Firestone 2400.
Thanks,
Al
ALMcKinney is offline   Reply With Quote
Old 03-29-2011, 09:30 PM   #2
grhodes50's Avatar
My tt dry hitch weight is about 250 lbs more than what you listed and my Equa-i-zer hitch handles it without air bags. My F-250 isn't squating and I don't have any handling problems. I think a good wd hitch such as the Equal-i-zer or Reese Dual Cam will be all you need.
I noticed that you listed your tt CCC as 4,665 lbs. WOW! About all the tt's I've seen in the weight class you listed have a CCC somewhere between 1,500 lbs and 2,500 lbs. I'm not sayin' your wrong, just I can't remember seeing one with that much CCC.
Good luck and happy camping!
Gary & Trish
2018 Nights Camped - 5
Old 03-29-2011, 09:43 PM   #3
grhodes50's Avatar
I just looked it up and your right. That trailer must be built pretty good to handle that much cargo.
26-FBSS
705 lb. - Dry Hitch Weight
6,165 lb. - Unloaded Vehicle Weight
10,865 lb. - Gross Vehilcle Weight Rating
4,662 lb. - Cargo Carrying Capacity
29 ft. 9 in. - Exterior Length
11 ft. 1 in. - Exterior Height
96 in. - Exterior Width
51 gal. - Fresh Water Capacity
84 gal. - Grey Water Capacity
32 gal. - Black Water Capacity
16 ft. - Awning Size
Nice floorplan.
Gary & Trish
Old 03-29-2011, 10:12 PM   #4
rracer5's Avatar
I only have a Chevrolet 1500HD (that's a half ton on a little steroids) with NO special suspension add-ons. My TT is the Prime Time Lacrosse 303 RKS weighing 7097 lbs dry and a tongue weight of 945 lbs (correct me if I'm wrong Gary). But, with my Reese Dual Cam, I have no "sagging" of the rear suspension and no handling problems. Your F250 should have no problem in it's stock configuration.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 03-29-2011, 10:43 PM   #5
grhodes50's Avatar
As posted on this forum many times, the only way to know your tt's true weights is to take it to the scales and weight it.
PT's web site gives the 303RKS a CCC rating of 2,596 lbs. I just checked the yellow sticker on the side of my tt and it states not to exceed 4,232 lbs in cargo!
Regardless, the OP's F-250 should handle the tongue weight without airbags. As stated above, just make sure you have a good wd hitch.
Gary & Trish
Old 03-30-2011, 08:22 AM   #6
KyDan's Avatar
Airbags or not.
NOT.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-30-2011, 08:42 AM   #7
Bayouownbeer's Avatar
A BIG NOT! I had a JAG 30FT same floor plan as yours before my 5er and had no problems could barley feel it back there LOL.
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 03-30-2011, 06:32 PM   #8
Thanks!
26-FBSS
Nice floorplan.
Old 03-30-2011, 06:36 PM   #9
I had my dealer order the equalizer 1400/14000 hitch which they stated they would install.
Old 03-30-2011, 06:51 PM   #10
grhodes50's Avatar
I would think the 1200/12000 hitch would be more than enough. Since your tt's GVWR is 10,865 lbs and according to the dry weights you have a tongue weight of approx 11.5%, the most your tongue weight should ever be is approx 1,250 lbs. That's if you were maxed out on your tt's CCC, which I doubt you would ever load 4,662 lbs. in your tt.
I haven't experienced it, but I've been told that if you have too heavy of spring bars it could put more stress on the tt's A frame which may result to damage of the tt's A frame.
Maybe someone else has heard of this as well?
You might want to check into that just in case what I was told was correct.
P.S. I just sent a message to Equal-i-zer asking them. I'll post what they have to say as soon as they let me know.
Gary & Trish
airbags
