Old 04-07-2013, 08:10 PM   #1
Capt. Mike's Avatar
AirLift brand air bags
Is anyone running AirLift brand air bags on their TV? I put a set on my Silverado and they work great, but tend to lose air pressure more quickly than I might have thought. I checked all of the fittings on the air lines and sprayed them with soapy water, but can't find a leak - at least one that is noticable - but they still lose air at the rate of about 1 lb every couple of minutes. Fortunately, I also installed an on-board compressor, so re-inflating them isn't a problem, just annoying. Any thoughts?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-07-2013, 08:16 PM   #2
skullskidr's Avatar
Hey mike,
I have the 5000s on mine and I lose pressure sometimes at pressures <15 psi. It would seem you could hear pressure like that escaping. Maybe the plastic compressor housing?
2012 Ford F350 Super Duty 4x4
ProPride 3P
2013 Windjammer 3006WK
1973 Camaro RS, LS6/475hp, 6spd
skullskidr is offline   Reply With Quote
Old 04-07-2013, 08:20 PM   #3
speedcat's Avatar
Originally Posted by skullskidr View Post
Hey mike,
I have the Firestone airbags on my Silverado and do not loose any pressure....now. When first installed lost pressure out of one but not the other. The problem was that the air tube was not cut evenly where it fit into the gauge. Tube was pulled and cut evenly and now I don't loose any pressure at all.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 04-07-2013, 08:21 PM   #4
Capt. Mike's Avatar
Hey mike,
These are the 5000's, too. I checked the connection at the front of the plastic compressor, but didn't think to check the compressor itself. I'm thinking it is sealed, so no opening it, but you are right...you would think that I could hear it at that rate.
Thanks for the suggestion.
Mike and Yvonne
Old 04-07-2013, 08:24 PM   #5
Dodge Guy's Avatar
1 lb every 2 minutes is a big leak! there has got to be something leaking somewhere! I have the Arlifts on mine and the most they lose is 3-4lbs in 4-5 days in very cold weather.
Keep looking!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-07-2013, 08:40 PM   #6
transamz9's Avatar
Yes, you have a bad leak somewhere. I don't lose a pound in 3 days. You are losing it in minutes.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 04-07-2013, 08:42 PM   #7
Took the AirLift bags off my 95 Silverado, installed them on my 2000 and then to my 2005 and have never had a leak in over 15 yrs. The only time the onboard compressor comes on is if the pressure is set at 10 or 15 lbs and I hit a bit bump and it releases out of the dash control. I would suspect a leak somewhere around the compressor or the dash control unless it is the wireless type.
Old 04-07-2013, 08:45 PM   #8
Capt. Mike's Avatar
Nope, it is the wired compressor.
Mike and Yvonne
Old 04-07-2013, 09:03 PM   #9
I would pump them up to max pressure and do a soapy water check on all fittings again and if nothing shows, concentrate on the compressor connection and case. Mine has been under the truck for 7 yrs and I don't remember what it looks like. (CRS has taken over)
Old 04-08-2013, 11:53 AM   #10
jevanb's Avatar
I put the 5000 on a few weeks ago and have only towed once (sure is great) I also have the load controllerII mine is set @ 5psi then self inflates, I can let it sit for days and I lose no air. check the air lines for straight cut . I have about 6 t fittings and none leak
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
