04-01-2016, 08:07 AM
#41
Originally Posted by mnoland30
I purchased a K&N filter for my Jeep diesel. When I read the directions, it said it wasn't good for dusty conditions. I live in Albuquerque, and it is dusty from March to June in a good year. Just drove through a dust storm on the way back from Lake Powell. The K&N is still sitting on the shelf in the garage.
I had a service manager @ a FORD dealership tell me back a couple of years ago that they were seeing a lot of engine damage do to K & N Filters ???
04-01-2016, 11:22 AM
#42
Originally Posted by stevensmith2859
Fortunately, back east, we dont have very much dust
As for dust, we have a home in the upper mid west where you might not think dust is a problem. But drive through a construction zone, down a gravel road, or worse, follow behind someone down a gravel road and there is plenty of dust. There is dust crossing the roads when the farmers are working the fields. If you have to wash your vehicle regularly, it's because of dust. We had a farm tractor overhauled and the mechanic did not attach the air filter to the carb properly, leaving a very small leak at the connection. Dust ruined the motor in less than two hours.
You may also want to talk with DW before investing. This air cleaner howls loudly. If your pulling the TT, it will be howling a lot. It was difficult to hear each other when accelerating, pulling a hill, or on any downshift when accelerating. The only time it was tolerable was at idle. When we bought a new truck with standard air filter, we really appreciated quiet. Life is good.
There are a lot of gimmicks out there purporting to give improved gas mileage. To verify the torque and HP hype, you would have to put it on a dyno. The folks here are giving you their best advice having had one. Not one of these posts has been favorable.
04-01-2016, 11:44 AM
#43
Camp Bartender
It certainly seems that way! Thank you everyone for the input!
2017 Dodge Ram 1500 Big Horn, 5.7L HEMI
2015 Forest River Wildwood 28DBUD
2015-2018: 20 Trips, 61 Nights Camped
2018: 5 Trips, 15 Nights Camped
2019: 2 Trips, 10 nights so far......
04-01-2016, 02:21 PM
#44
In regard to the pistons clapping when it is cold on my 1997 Yukon V8 I think I will go for the syntetic oil but what grade that you recommand?
I have 160K on the engine and I always use regular 10W30 with somme aditif.
I use it mainly for pulling my Palomino S21 hybrid.
Thank you.
04-01-2016, 02:59 PM
#45
Tinkerer and Putterer
The engine clearances dictate engine viscosity. Too thick of a viscosity on a tight tolerance engine is just as bad as too thin a viscosity on a high stress situation like a diesel. Stick with the viscosity recommended in your manual or posted on your oil cap to be safe.
04-01-2016, 03:48 PM
#46
They recommand 10W30 for my engine but syntetic oil grade comme as 5W30 , 15W40 etc.
So do i go for lower grade in syntetic oil or higher grade?
04-01-2016, 04:14 PM
#47
Synthetic oil can be recycled, thus may be cheaper. You can't go wrong with a good grade oil such as Mobile 1.
04-01-2016, 07:11 PM
#48
Yes but what grade would be better in Mobil1 brand for my engine?
I cannot find 10W30 in syntetic Mobile1.
04-01-2016, 09:02 PM
#49
04-01-2016, 09:44 PM
#50
https://www.zoro.com/mobil-mobil-1-1...B&gclsrc=aw.ds
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
04-01-2016, 10:15 PM
#51
Synthetic doesn't break down like regular oil. They've done tests with big rigs and run 1,000,000 miles without an oil change. They changed the filters often. I change my oil once a year whether it needs it or not. I've been doing it for years on all my vehicles and never have had an engine problem.
Synthetic is great and doesn't break down, but it does get just as dirty(silicon in oil analysis) as dino oil. For extended change intervals, a centrifuge or 1 or smaller micron bypass filter is essential. A stock filter is 20 to 40 micro. Changing the filter will not remove the small stuff. Oil sample is the only way to know the condition of the oil. Periodically, they'll add a little fresh oil, usually filling the bypass filter is enough, for refreshing the additive package.
USMC 68 -70
04-02-2016, 07:07 AM
#52
The Canadian Walmart dont carry Mobil1 10W30 syntetic but I will check with Canadian Tire.
Thank you.
04-02-2016, 07:12 AM
#53
Thank you.
Our Sam's does not have 10 w 30 anymore either,,,
They only have 5 w 20 & 5 w 30 !!!
04-02-2016, 09:53 AM
#54
If you are not aware of the quantity of oil required for the 5.7 Hemi, check your owner's manual. I believe it is 7 quarts, but as I said, make certain because overfilling is as bad as not enough.
Amazon carries Mobile 1.
http://www.amazon.com/s/ref=nb_sb_ss...1+%2Caps%2C487
04-02-2016, 10:02 AM
#55
I will be checking my owners manual before I change the oil in my V-10 !!!
04-02-2016, 10:46 AM
#56
I don't have access to our manual, but came across this.
Ford V-10 Engine-Oil Capacity
04-03-2016, 05:41 AM
#57
Nor do I,,, ours is snowed in this morning !!!
LOL !!!
Thanks for the link !!!
04-03-2016, 09:14 AM
#58
Camp Bartender
The 5.7 hemi holds 7 quarts
04-03-2016, 09:32 AM
#59
LOL !!!
It was 85 and a shower in FL. The band of really heavy weather is north of us. But the 2500TS is probably under the same pile as yours. It won't be long now!
04-03-2016, 09:45 AM
#60
Spring can bring some pretty crappy weather !!!
