04-28-2014, 08:56 PM
Am I being pushed or pulled by trailer?
We took our new and first TT out this past weekend and I cannot figure out if I am being pushed or pulled by the trailer. Up until this point we have driven on flat terrain and when I apply the brakes and let off I noticed no difference from when I drive our TV without the trailer. This past weekend we went to an area that has many more hills, Uwharrie area in NC. I noticed when going downhill in particular I would feel a bump when letting off the brake pedal. I tried adjusting the controller gain and could only get it to stop when turned down to 2 or 3. I also tried using the manual control only but could not make the bump occur. Would the bump be an indication of the trailer pulling and then TV jumping when the brakes are released or the opposite?
We have a trip into the western NC mountains planned in a couple of weeks. The steepest grade is around 6% for 5 or 6 miles so I would like to get things balanced better before we hit it.
My TV is a 2001 Explorer and the TT will be loaded weight of 3000 Lbs. I'm using a Primus IQ for my controller. Thanks.
04-28-2014, 09:20 PM
Could be either, and both are somewhat normal on a hill. Everything down to the hitch pin can move just a little bit (but you may want to get into the habit of checking all of your hardware every time you move it...excessive play could cause some of that). I don't even notice it now, but I noticed every little noise when I first started pulling a trailer. I wouldn't worry about it unless it's a major jolt. Just set it up like the instructions say in regards to gain and you'll be ok. It'll adjust for the hills on its own.
04-28-2014, 09:36 PM
You're on the right track, and honestly it sounds like you're adjusted correctly, for my taste at least. Downhill I like for the trailer to do a bit more braking than it actually needs so that I know all is right. So the trailer is pulling back against you, then pushing you when you release the brakes but the engine braking is still slowing you.
It's normal and in my eyes desirable, I like knowing that things are working right back there.
04-28-2014, 10:14 PM
You do not want to over heat your trailer brakes, just as you do not want to over heat your tow vehicle brakes. Read the Manuel for the controller and set it up that way.
Brother Les
04-28-2014, 10:31 PM
I have adjusted it to the specifications. It is made by Tekonsha and adjusts just like their other controllers (Prodigy, P2, P3). On flat roads it seems to function just fine. It was with the hills that I started feeling a bump or jerk when letting off of the brake. Depending upon whether it is pushing or pulling I would need to make opposite adjustments to the gain control.
04-29-2014, 02:12 AM
are you using a WDH with sway control?
is your Exploder a v-6 or v-8?
4 door or 2 door?
04-29-2014, 05:43 AM
What you describe sounds to me like slack in the hitch being taken up, either by a little slop in the hitch pin or at the coupler. A little slop in the hitch pin is normal but I would double check the tightness of the ball and the coupler on the ball.
Sent from my Kindle Fire using Tapatalk 2
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
04-29-2014, 06:32 AM
4 door or 2 door?
Thanks for the responses so far.
I'm using an Equal-i-zer hitch and ball. All of the bolt's and ball are torqued to spec from the instructions. My Explorer is a 4-door, V6.
I would do some experimenting but I don't have any relatively straight roads with steep hills in my area that are lightly traveled. They either have so many curves that it requires two handed steering, are flat or have fairly heavy traffic.
04-29-2014, 07:45 AM
Good idea about slop. All bolts are torqued to the hitch specs. Based on your update I installed the ball mount. I cannot get any in and out movement of the shank in the receiver but I do get some side to side and up and down movement. I hooked the trailer up and could not reproduce the sound bouncing it around but it is not the same motion nor can I put the same stresses on it like driving does. Looking at how the coupler locks onto the ball I can see how it might allow for forward and backwards movement under pressure. I don't think it is adjustable but that will have to wait for another day when it is dryer outside. Here is a picture of my coupler:
04-29-2014, 08:00 AM
There is a nut under the hitch on most couplers that can be tightened also. You might check that.
04-29-2014, 08:01 AM
Try applying trailer brake manually then put truck in neutral and let off truck brake should show up then. Might just be drawbar in receiver your hearing making the bump, pull drawbar out and apply grease to inside of receiver and outside of drawbar and put back together may take care of it. There is always some slop there considering there is one pin holding it in place. I'm betting that's what your feeling.
04-29-2014, 08:27 AM
Keith, everything that you are 'feeling' is 'normal'. There is no 'adjustment' to tighten the 'ball' into the hitch.... the tongue hitch needs to move around on the 'ball'...forward/backward/up/down/side ways..... just a little bit so that it does not 'bind up'.
Let's get back to the brake actuator.... I believe that you need to 'set it' and leave it alone...... to 'set' it..... get on a flat street with no traffic and slowly move down the street (coast). gently and slowly push on your brakes a little. You should 'feel' the camper very gently tug on the tow vehicle. Back the brake off at the actuator and try again.... do you still 'feel' the camper tug on the tow vehicle.... do this until you do not 'feel' any tug..... at that point the camper and tow vehicle are almost 'neutral' in the braking. You want to now put just a little braking back on the camper and then Leave The Brake Controller alone....
The idea on this is that the camper does not 'stop' or slow down the vehicle/tow unit 'train'.... the braking of the camper 'first' is to barely slow the camper first to keep it in a straight line behind the towing unit. The more 'brake' pressure that you apply to the tow unit the more 'brake' pressure will be applied to the camper brakes by electric impulses. This is why you Do Not 'adjust' your brake actuator 'on the fly' going up and down hills as it will get out of wack on your fine tune adjustment when you went down the no traffic street. The 'actuator' should have a 'hand brake' on it so that when you do go down a long Grade, you can by hand manually (after taken foot off the gas pedal) 'slow' the camper down a little and keep the camper going in a straight line. If you need to slow the tow unit and camper down then use on the tow vehicle brake pedal. The camper brake will 'engage' first, but only slightly more and going down a Grade will seem as if it is not engaged at all, but know that it is if 'set' correctly. Leave the controller adjustments alone while out driving because if you 'tighten' the brakes up too much on your camper, very bad things could happen if your camper brakes 'lock up' on you and send you into a skid or toss you in the ditch or in front of someone. Your tow vehicle should be 'stout' enough to pull and stop your camper with no camper brakes at all.....
If I have written to much or it sounds like I am talking over your head or down to you I apologize, as I mean only good things. I have said it many times here before. Safety first and always....
Adjust your controller once and leave it alone. For long down hill grades, slight pressure on your tow vehicle brake pad.... (do not worry if the camper 'hits' you a little), if you want more braking on the camper going down hill, use the hand brake on the controller only.
Brother Les
04-29-2014, 08:47 AM
X 2
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
04-29-2014, 08:51 AM
X2. The nut under the coupler is what determines how tightly the coupler is clamped to the ball. You want that fairly snug.
2013 Roo 183
04-29-2014, 08:54 AM
...Your tow vehicle should be 'stout' enough to pull and stop your camper with no camper brakes at all...
Agree up to here. No way, that's why there's state laws requiring trailer brakes. Heck, even semi's can't do it!
04-29-2014, 08:56 AM
If you are using a brake controller that has a boost feature built in you may experience some jolting from this feature depending how you have it set.
I tow a 37' bumper pull trailer at 9,000 pounds so I have my boost set at the max. As soon as I touch my brake pedal the brake controller sends a quick shot to the trailer brakes to get it slowing down first to avoid the trailer pushing the truck...
May be another thing to look at.
But OC is correct with the adjustment on the keeper nut on the coupler. Many folk have no idea it is there...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
04-29-2014, 09:36 AM
When you feel the "jolt" does it tend to move you back in your seat or towards the steering wheel, and is it with any "force". When you apply your truck brakes, you shouldn't have any inertia that sends you back in your seat. When letting your brakes out on a downhill, your trailer may release a little quicker and may give you a "push", but this is somewhat normal. Maybe I missed it, but I also didn't see what model of brake controller you are using. A proportional brake controller will help in most all instances of "grabbing & release".
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
04-29-2014, 09:43 AM
Brother Les said, Your tow vehicle should be 'stout' enough to pull and stop your camper with no camper brakes at all.....
Even I disagree with this up to a point...... (and we are not talking about Semi brakes, which are air brakes, which must have to have air to keep the brakes from coming on... ) we are talking about electric brakes. Electric impulses that can very up and down the voltage scale and like wise the stopping power of the camper brakes rely on the electrical voltage. Not enough and they are useless... working fine, one has that 'feel' that they are working fine and acting as if they are mimicking your vehicles hydrolic brakes. Too much of a voltage pulse and your camper brakes can lock up and many bad things can happen. I don't trust my life and my families life on camper brakes. Reading the suggestions of the usage of camper brakes, it is heavily suggested that when it is raining to Not even have your camper brakes activated. The wet pavement could throw you into a skid. Hense, my statement of having a tow vehicle that is stout enough to Pull and Stop your camper with no camper brakes at all. I don't like stating that as some may think that it is fine to not have camper brakes and that is not the case at all. Set yours correctly and use them correctly, but also don't get in a situation of where your life and the lives of others fully depend on them to stop you safely.
(clear as mud???)
Also, about the tongue/ball adjustment. Been pulling campers for way to many years that I want think about sometimes. I just plain forgot about that adjustent. Be very careful about adjust that too tight. I have never had to adjust one in my life and would really wonder about having to much 'slack' in that area? You do have the right ball size, correct?
Brother Les
04-29-2014, 09:52 AM
(clear as mud???)
Locking the brakes on the trailer will actually not cause any substantial issues other than flat spotting trailer tires if done for too long/far.
I personally set my trailer too high braking wise for the fact that when I need to hit the brakes in a hurry I want to make sure the trailer stays straight. Maximum braking force to the trailer will ensure that. Even if the trailer tires lock up the trailer will stay in line behind my truck. (I dont have it set to where my tires lock up at all but just saying)
I compare it to a bicycle. Most of us when we were younger would ride around and lock the rear tire and make it slide, I never lost control of it from what I recall. Same thing with a motorcycle. I will jam the rear brake MUCH harder than the front in a situation of rapid braking.
Just my thought.
04-29-2014, 10:11 AM
Tractor/trailer combos are NEVER allowed to go down the road without brakes "activated" on any trailer. It is true that it takes air to "Activate" the brakes. Same goes for the trailer, it needs air to release the brakes before the trailer will move.
With that said, My truck will stop my entire rig but the brakes will suffer a very short life span if I don't use the trailer brakes. Electric, Air or Hydraulic brakes are meant to stop a vehicle in a safe distance for the amount of weight it can carry.
Be safe out there!!
Even I disagree with this up to a point...... (and we are not talking about Semi brakes, which are air brakes, which must have to have air to keep the brakes from coming on... ) we are talking about electric brakes. Electric impulses that can very up and down the voltage scale and like wise the stopping power of the camper brakes rely on the electrical voltage. Not enough and they are useless... working fine, one has that 'feel' that they are working fine and acting as if they are mimicking your vehicles hydrolic brakes. Too much of a voltage pulse and your camper brakes can lock up and many bad things can happen. I don't trust my life and my families life on camper brakes. Reading the suggestions of the usage of camper brakes, it is heavily suggested that when it is raining to Not even have your camper brakes activated. The wet pavement could throw you into a skid. Hense, my statement of having a tow vehicle that is stout enough to Pull and Stop your camper with no camper brakes at all. I don't like stating that as some may think that it is fine to not have camper brakes and that is not the case at all. Set your correctly and use them correctly, but also don't get in a situation of where your life and the lives of others fully depend on them to stop you safely.
(clear as mud???)
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
