Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > Towing, Hitches & Toads
Old 05-05-2011, 01:57 PM   #11
flyrotor's Avatar
I have never heard of an issue with a pin shear, even in crashes. I have seen instances where the 2" shank has sheared from an impact, trailer balls that have sheared, trailer tongues twisted and wrapped into a new shape, trailer axles pulled from underneath the trailer, but never a sheared pin.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 05-13-2011, 08:57 AM   #12
thebrakeman's Avatar
Originally Posted by prof_fate View Post
1/2 dozen 9/16 grade 8 bolts to hold the hitch to the frame
4 more to hold the ball part of the trailer to the toungue
2 even larger bolts hold the two pieces together that make up the ball and receiver assembly, and mine came with shims to be sure there was no freeplay in there.
a 1" shank ball isn't strong enough, so you gotta get a 1 1/4" shank ball.
And then you gotta bolt this together at hundred of pounds of torque.
The only thing really keeping the trailer attached is a 1/2" pin that isn't torqued in at all, rattles in it's holes and weighs less than one of the bigger nuts.
If the pin is strong enough then everything else seems to be overkill.
The typical bent pin is such a stupid easy part to make, that it would be silly to make them at lower grades. So they probably make them for the largest pull-behind trailers (20,000 lbs?). To make the same geometry pin with a material grade only strong enough for a 10,000 lbs trailer, would drive up inventory costs, probably be a grade with imperfections, and likely only save us $0.25. Of course there is a smaller pin, for use in the 1¼" Class 2 hitches.
As far as the other fasteners in the system being overkill, I disagree.
That bent pin is placed in pure shear. There is no tension or compression loading on that pin. Conversely, the other fasteners you mentioned are threaded joints, place in tention, to produce clamping load. Any steel fastener or pin can take far more shear force than tension.
I remember an axle joint I was working on (at my job), where you had four (4) 3/8" threaded studs holding the brake assy to the axle flange. During some extreme powertrain durability tests (forward/reverse transmission cycling), the drivers could hear the brake slipping thru the axle joint, and "clunking" against the fasteners. The 4-bolt joint was not strong enough to prevent the slippage...tightening the bolts further would break the bolts. But the impact from the holes banging the bolts in shear wasn't even close to damaging them. The noise was the complaint, not damaged bolts. The solution was to increase the bolt size and bolt pattern diameter. Not to protect the bolts from shear, but to allow the bolts to take a higher torque, and prevent the slippage in the first place.
2004 Surveyor SV261T UltraLite Hybrid
thebrakeman is offline   Reply With Quote
Old 05-13-2011, 10:42 PM   #13
Villa Estate 392FLFB
The_Stuff's Avatar
This is what happens when you try to pull start a semi :P (NO, IT WAS NOT ME)
So that shows how much strength that the pins have! I cant find the pin picture but it was just slightly bent.
ALSO stay away from the pins that have the little swivel part at the end that is supposed to hold it in. well they dont and we lost a sled trailer once..
One state/province at a time!
The_Stuff is offline   Reply With Quote
» Online Users: 589
126 members and 463 guests
2000XLifted, 4Jeeperz, 5Galvs, acadianbob, autorot8, AVid, bean, bear17, Bearcat55, BlakeB, bob34787, bob7794, Borwick, brookside, bryndlwulf, Busman1947, buzzmonster, camper_Lucy, caper, Capsfloyd, Cascade Bob, cat1956, cdbus, Char_n_Kath, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, dasimser, dec1952, deerslayer, dimurrrw, dnicekid, donn, Douglasdh62, Drmstx62, DSN46, dtolar, duchie, dunnnc, elind, flc, fordmantpw, forthefunofit, FreedomTracker, gator14, gbpacker, GeorgieGirl, gmurrell, Gquist, gsocamper, Hammertat, Happy Vibe, herk7769, hokiecampers, icebrew, iscotty123, isz, JamesR, Jeep4Two, JJones, jkinger, jmswms, JoeR, joess, Joker, jphillips1075, judy3972, kegoneill, LFugate, lmcleister, louincal, maggiek, micalo, Mr. Legato, MT28rk, mtl roofer, munty, NanaKaren, NancyTX, pandkm, Pharmofish, phuss, Pinesman, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, prof_fate, pwrplay, rawlus, Redheaded blue tick, Rescue1, rickthelen, rjshiflet, rschoono289, rstewart06, russpat, rwzahm, Sailfish Bret, sbond, SDENN4281, shineysideup, Skippkon, skippy31405, snowbrid, softwarejoe, Stagger, Stank Bait, Stinger, Tech Admin, texashatter, thaithco, tmmar, TN_Jeeper, Triguy, vinman72, wakamicamper, william.migues, willy, wneise, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
