Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Tech Talk > Towing, Hitches & Toads
Old 04-20-2011, 05:55 PM   #1
prof_fate's Avatar
Am I the only one that finds this strange?
On my van that we used to tow up to 2000lbs and on many previous vehicles with receiver hitches I've seen the same thing - a pin that holds the receiver in and takes the entire pulling (or pushing load) of the hitch.
Now on my new setup I had to get a 2 5/16 ball with a 1 1/4" shank, the bits that hang on the receiver weigh a good 50 or 60 lbs, going to tow mebbe 7000 lbs....and the only real connection is the same size pin, perhaps 1/2" diameter, that I've seen on light duty hitches.
Is there some engineering magic on that pin? I've seen balls and hitches with all sorts of weight ratings and I've seen spare pins - and never a rating on them!
Am I the only one that feels this is strange?
Jill & Chris, Wills (11) Evie (8) & Toby our collie (2)
2011 Grey Wolf 28BH
2001 Expedition EB 4x4 w/ Reese StraitLine Dual Cam, 5.7, 3.55
Nights camped 2011: 11 2012: 0 (so far)
prof_fate is online now   Reply With Quote
Old 04-20-2011, 06:13 PM   #2
Lou Amadio
herk7769's Avatar
Other than that pin is hardened steel and the hitch is soft steel, no.
My hitch shank pin hole shows wear (slightly elongated) from towing in just 1 1/2 years. The pin looks brand new.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
herk7769 is online now   Reply With Quote
Old 04-20-2011, 06:47 PM   #3
backin15's Avatar
I often think of all that weight riding on that pin when I am towing up a steep hill. But it is a hardened pin and since the gap between the reciever and the shank is so small it would take an increadible amount of force to shear.
2010 Flagstaff 25 DS
2004 Dodge 2500 Hemi
backin15 is offline   Reply With Quote
Old 04-20-2011, 08:54 PM   #4
leencharlotte's Avatar
I have been wondering the same thing... i just try to not think about that little skinny piece of steel holds all that together... lol
leencharlotte is offline   Reply With Quote
Old 04-23-2011, 07:35 AM   #5
04eddie's Avatar
Has any one ever seen one sheared. I have seen a couple bent before but they were bent when trying to pull out a stuck truck not during towing. I think when you are towing there is 400 or 500 lbs pushing down from tongue weight so the ball mount wont move enough to cause a shearing effect. just my thoughts
2004 Ford Expedition Eddie Bauer, 5.4L
2004 Wildwood LE 28FKSS
04eddie is offline   Reply With Quote
Old 04-23-2011, 10:21 AM   #6
Location: Jacksonville Florida - Home of the Jaguars !!!!
You can buy replacement pins with a locking end that are case hardened steel, and weight rated for 5000 lbs. aftermarket- I think I got mine at Advance Auto Parts. Works very well; had it almost 4 years, and still looks just like I bought it. I think it was made by Reese, but not positive. Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
Old 05-04-2011, 11:33 PM   #7
Don't forget about the toque that is applied to the verticle load. The retaining pin doesn't have to deal with this additional load, and the pins usually solid. so I don't really think of this issue.
zx5chris is offline   Reply With Quote
Old 05-05-2011, 07:32 AM   #8
prof_fate's Avatar
1/2 dozen 9/16 grade 8 bolts to hold the hitch to the frame
4 more to hold the ball part of the trailer to the toungue
2 even larger bolts hold the two pieces together that make up the ball and receiver assembly, and mine came with shims to be sure there was no freeplay in there.
a 1" shank ball isn't strong enough, so you gotta get a 1 1/4" shank ball.
And then you gotta bolt this together at hundred of pounds of torque.
The only thing really keeping the trailer attached is a 1/2" pin that isn't torqued in at all, rattles in it's holes and weighs less than one of the bigger nuts.
If the pin is strong enough then everything else seems to be overkill.
2011 Grey Wolf 28BH
Old 05-05-2011, 11:40 AM   #9
The pin only comes into play from horizontal pulling and pushing from power and braking applied from your tow vehicle. This is why that pin is not necessarily large, IMO. Randy
Old 05-05-2011, 11:59 AM   #10
The pin diameter is 5/8 on the Cat. 3-4 5 hitches! Youroo!!
» Online Users: 590
125 members and 465 guests
2000XLifted, 4Jeeperz, 5Galvs, acadianbob, autorot8, bean, bear17, Bearcat55, BlakeB, bob34787, bob7794, Borwick, brookside, bryndlwulf, Busman1947, buzzmonster, caper, Capsfloyd, Cascade Bob, cat1956, cdbus, Char_n_Kath, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, dasimser, dec1952, deerslayer, dimurrrw, dnicekid, donn, Douglasdh62, Drmstx62, DSN46, dtolar, duchie, dunnnc, elind, flc, fordmantpw, forthefunofit, gator14, gbpacker, GeorgieGirl, gmurrell, Gquist, gsocamper, Hammertat, Happy Vibe, herk7769, hokiecampers, icebrew, iscotty123, isz, JamesR, Jeep4Two, JJones, jkinger, jmswms, JoeR, joess, Joker, jphillips1075, judy3972, kegoneill, LFugate, lmcleister, louincal, maggiek, micalo, Mr. Legato, MT28rk, mtl roofer, munty, NanaKaren, NancyTX, pandkm, Pharmofish, phuss, Pinesman, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, prof_fate, pwrplay, Redheaded blue tick, Rescue1, rickthelen, rjshiflet, rob and lisa, rschoono289, rstewart06, russpat, rwzahm, Sailfish Bret, sbond, SDENN4281, shineysideup, Skippkon, skippy31405, snowbrid, softwarejoe, Stagger, Stank Bait, Stinger, Tech Admin, texashatter, tgarner2000, thaithco, tmmar, TN_Jeeper, Triguy, vinman72, viper48, wakamicamper, william.migues, willy, wneise, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
