Closed Thread
Old 01-13-2012, 06:17 PM   #21
MtnGuy's Avatar
Originally Posted by jim44646 View Post
My understanding is the ball does turn in the coupler. The coupler is lined with brake materal. I might be wrong.
Hmm....I might be using the wrong terminology in my previous posts. I consider the coupler the device that is on the end of the trailer tongue that locks down on the ball. The part that has the brake material is the head assembly in my mind.
MtnGuy is offline
Old 01-13-2012, 06:25 PM   #22
jim44646's Avatar
I suppose that's more the correct terminology.
jim44646 is offline
Old 01-13-2012, 07:30 PM   #23
leencharlotte's Avatar
There was another related video where he explains it i saw on youtube as well. Link
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline
Old 01-13-2012, 08:19 PM   #24
jim44646's Avatar
You would think the chain brackets would slide forward on trailer a frame. their just saddle clamped around frame.
jim44646 is offline
Old 01-14-2012, 09:42 AM   #25
President ProPride, Inc.
Sean Woodruff's Avatar
I hope he comes on to. I've been in the sway eliminating business for 15 years and for the life of me I can't see how the coupler isn't going to turn on the hitch ball. I see that the hitch ball shaft has brake material that damps it from rotating. I get that. However, that isn't the location of the trailer pivoting unless that hitch ball is locked into that coupler. When the trailer pivots the chain to the side of the pivot will slack unless the coupler is fixed to the hitch ball and pivots the entire shaft.
Sean Woodruff is offline
Old 01-14-2012, 09:46 AM   #26
RubenZ's Avatar
That's what it appears to do. The hitch ball and that plate where chains connect to seem to move together no? Because the plate goes onto the ball shaft with a pin.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline
Old 01-14-2012, 09:51 AM   #27
Yes, the hitch ball, shaft and plate all rotate together. How do they rotate when the coupler of the trailer IS NOT connected to the hitch ball? The trailer coupler, sitting ON the hitch ball, rotates during trailer sway.
I take exception with the "No Sway" title of that video.
Old 01-14-2012, 10:16 AM   #28
fonzie's Avatar
There is a difference between trailer sway and trailer fishtailing. I think some people think that trailer fishtailing (moving right to left) is trailer sway??
Fonzie
fonzie is online now
Old 01-14-2012, 04:18 PM   #29
MtnGuy's Avatar
I think if they get rid of the chain and replace it with a spring bar that does not move in the snap up bracket, they will have a winner. I understand how the chains can put some of the weight back on the front of the tow vehicle, but not a lot of weight. That system may work for light trailers, but I don't see how it is going to work for big trailers.
MtnGuy is offline
Old 01-17-2012, 02:49 PM   #30
Andersen Weight Distribution Hitch
I joined this Forum in hopes to help answer any questions or concerns on the New Andersen Weight Distribution Hitch along with all of Andersen Manufacturings Hitch Products.
The Weight Distribution Hitch comes in one size that fits all. So only 1 Model needed. Unparalleled Sway Control Automatically Adjusts To Your Load. 14,000 lbs GTWR and
1,400 lbs tongue. Weighs only 53 lbs. Easy To Install - No Leverage bars needed. Drop Hitch comes in a 4" or 6" Drop and you can also pick up an additional 2" x 2-5/16" accessory ball if needed. All you have to do is pull one pin and use as a standard 2 5/16" ball mount without Weight Distribution. Comes with TMD "True Motion-Dampening System, and has a patented shock absorber that prevent your vehicle from bouncing like a traditional weight distribution hitch. Because of its
Durability and Strength and much testing on this product Andersen Manufacturing is backing this product with a Lifetime Limited Warranty!
Andersen Manufacturing is offline
Closed Thread
