Closed Thread
Old 01-21-2012, 07:45 AM   #51
Triguy's Avatar
Originally Posted by RubenZ View Post
ahhhhh i See now how it distributes weight.
I also see it. Thanks for the video Andersen Hitch guy.
I imagine that the amount of weight distributed will be similar to a spring bar system but would like to see before and after CAT weight sheets.
Andersen Hitch guy - would you do a favor and weigh a truck and RV or similar trailer at a CAT scale so we can see the weights. It would be helpful to counter skeptics (okay - that would be me). The following would be good to see.
Before hitch weights:
TV front axle
TV rear axle
Trailer axles
Hook up hitch to distribute 12-15% of the trailer's weight and reweigh. Attach pdf's of both sheets to this thread.
I know this might be asking a lot but I (and I think others) would like to see the proof that this is distributing the weight accordingly and the CAT sheets are the proof that's in the pudding.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Triguy is offline
Old 01-21-2012, 10:57 PM   #52
TV front axle
TV rear axle
Trailer axles
Yes! Sounds great I will get that done this week and post the results. Also our draftsman is still working on the diagram I will post it sometime this week as well.
Andersen Manufacturing is offline
Old 01-22-2012, 07:02 AM   #53
So when you hook it up and tighten the nut to remove the chain slack are you bottoming out the nut? Or do you torgue it dependent on how much weight you want to transfer? I would think you'd have to torque it to a certain amount each time, no?
Len & Cheri is offline
Old 01-22-2012, 08:15 AM   #54
Sounded to me they like to see 1/4 inch compression on that bushing.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline
Old 01-22-2012, 10:39 AM   #55
acadianbob's Avatar
Yeah, me too! Now just the question of whether those brackets are going to have a hard time staying put with the lateral forces in play.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is offline
Old 01-22-2012, 10:42 AM   #56
acadianbob's Avatar
It was thinking along similar lines. When you go to tighten that nut on the end of the chain, you would certainly want to be consistent as to how much it is tightened each time. Torque wrench? OR? . . .
Old 01-22-2012, 11:10 AM   #57
MtnGuy's Avatar
Maybe count the number of turns each time ??
MtnGuy is offline
Old 01-22-2012, 11:19 AM   #58
wneise's Avatar
Don't think it would matter that much. Tightening one chain a little to much will just rotate the bracket/ball combo and put more tension on the opposite chain until both are the same tension. The one thing I think you want to look for is how much do the rear of the TV and the front trailer droop. Both should ne as close to level as possible for proper WD.
wneise is offline
Old 01-22-2012, 11:37 AM   #59
Hob
It seems to me, there is a lot of speculation of the adjustments. Tighten it until is compresses about 1/4". That sounds like something my dad would have said when working on the manure spreader. I was raised on a farm and we did a lot of the "about" measuring. I found, after joining the Air Force, close or about only counted in horse shoes and nuclear weapons. That was in the mid 60's, to my way of thinking we are a little more precise than that today.
Hob
Hob is offline
Old 01-22-2012, 03:48 PM   #60
acadianbob's Avatar
I think you are right, but that would be a real pain each time. I could do my Reese with my eyes closed in about 90 seconds. I'm still intrigued with this design though.
Closed Thread
