Old 07-06-2019, 06:15 PM   #1
Post Andersen No-Sway CAT numbers
These are the CAT scale weights I got today. The Andersen No-Sway transfered 60 pounds to the steer axle and 40 lbs to the TT axles and removed 100 lbs off the drive axle. I tightened the bolts on the chain 4 revolutions after snugging up by hand. I could have tightened another 2 or 3 revolutions but do not think much more weight would have transfered.
Thought I would post the numbers since some discussion has been around the weight transfer of the Andersen no-sway but I have not seen any numbers posted.
TV only
Steer axle 3100 lbs
Drive axle 2180
TV and TT w/o WD
Steer axle 2760 lbs
Drive axle 3580 lbs
TT axles 6380 lbs
TV and TT with WD
Steer axle 2820 lbs
Drive axle 3480 lbs
TT axles 6420 lbs
Gross weight 12,720 lbs
TV hitched w/o WD 6340
TV hitched with WD 6300
TV only 5280 lbs
TT only 7440
Tongue weight 1060
TV 2016 F150 XLT, FX4, 5.0 Coyote
TT Salem 2014 27RKSS
Weights are loaded to camp.
2016 Ford F150 Scab 5.0
2014 Salem 27RKSS
Archg38r is offline   Reply With Quote
cat, sway
