Old 08-14-2014, 12:25 AM   #1
harvester
Send a message via MSN to harvester
andersen no sway hitch
I have had a chance to use this hitch while driving through British Columbia,Canada.This province has all the driving challenges you will ever come up against having some of the extreme grades that tax the towing vehicles ability and the hitch to perform.The andersen hitch was everything that I could have asked for in that it was anti sway as advertised.I Was buffered by severe cross winds and by passing big rigs and noticed no sway.The hitch was very easy to hook up and took just a few moments.This is a keeper.Harvester.
harvester is offline   Reply With Quote
Old 08-14-2014, 08:07 PM   #2
thestrangebrew's Avatar
Just curious what your TV/TT combo is and how much weight the Andersen distributed back to the TV. I also have the Andersen WDH, I've only used it once so far and had zero issues with the wdh, but in my research prior to purchasing, I read alot about it not being able transfer the weight back to the TV for anything with a tongue weight of 800+ lbs (if I remember correctly).
2022 F250
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 08-14-2014, 09:22 PM   #3
harvester
Anderson hitch
My towing vehicle is a 2010 Silverado with an added max tow package.This package entails a bigger engine (6.2 L) that puts out 405 hp and 415 lbs of torque,heavy suspension and a 373 rear end.The trailer is a Terry 250K (26ft)nd would weigh about 6000lbs loaded.When hooked up together the adjustments that I made has the trailer level and the truck level. These adjustments are something you have to work at manipulating both the chains and the height of the ball.I would say that I was able to move the weight forward satisfactory. something I almost forgot the transmission is a 6 speed manu matic. Harvester
hitch, sway
