Old 03-27-2015, 03:46 PM   #21
Blog: RVroadtripper.com
hbillsmith's Avatar
Used the Andersen WDH for 3 years towing a 6,500# TT. Performed as advertised. No sway, no noise, easy to put on and take off, stores in a 12" by 12" tub when no in use. I compressed the spacers to the 7th thread and that moved 140# up to the steer axle and about the same back to the trailer axles. My SUV's receiver was rated at 600# and I was able to manage the load just fine.
Conclusion: Recommended without reservation.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 09-28-2015, 06:16 PM   #22
I did extensive research before choosing the Andersen "No Sway Hitch System". After my experience using it to tow over 1,000 miles, I quickly became a big fan of this product and cheerfully shared with anyone willing listen why I think it is a great performing hitch. It is light, easy to put into operation, and has improved my overall towing experience. I can also now share how great I think the team is that stands behind this product. I originally purchased the system with the 8" drop for another tow vehicle. The 8" drop was not quite right with my new tow vehicle. Andersen sent me the 4" drop without charging me for it and I believe it will work perfectly. I doubt that you can find a better product with better Customer Service, Anywhere!
2016 Micro Lite 25DKS, 2015 F250 6.2l Lariat 4x4 3.73's
rmillermtsu is offline   Reply With Quote
Old 09-29-2015, 06:19 AM   #23
Made a believer out of me. After towing 5ers for over 15 years, recently went back to TT (DW tired of steps) I was very skeptical and concern about handling. Prior to the 5ers I had 3 TTs, all with the older bar, chains and friction control. Not knocking that system, just remember how it worked. Purchased Andersen WDH after much research and couldn't be happier. This 34' TT tows every bit as good as my 37' 5er.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 09-29-2015, 10:54 PM   #24
Cougarfan's Avatar
I've had both. I don't think I'll ever go back to the traditional WDH again. The Andersen works as advertised. The only issue I have is that the brackets tend to slip so I'm going to have a friend tack weld them to the trailer frame.
I got the Andersen because the other hitch head was getting too heavy for me to lift. I didn't want to move to a 5th wheel or motorhome so tried this hitch first. Glad I did.
Laura
2015 F150 XLT Sport 4WD 3.5L EB
2014 Freedom Express 246RKS
Cougarfan is offline   Reply With Quote
Old 09-29-2015, 11:17 PM   #25
Wayne Joan's Avatar
I used the Andersen on my TT before going to the the 5er. It was a great improvement over the old bars and chains. I still have my Andersen if anyone is interested in a used Andersen let me know.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
Old 09-30-2015, 05:49 AM   #26
Michael4017's Avatar
What would the WDH go for and would it be cost effective to ship as I live in NY.
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is offline   Reply With Quote
Old 10-05-2015, 03:14 AM   #27
I am very happy with my experience with this hitch, but I cannot emphasize enough the importance of making sure you order the correct length drop/ rise. Many prospective buyers may think, like I did, that the 8" drop offers the same hole positions adjacent to the receiver as the 4" model. This is not the case, which means you could have a problem leveling your TT if your hitch needs to be mounted close to your receiver output. Because I needed to mount my hitch closer to my receiver output with my second tow vehicle, the TT would not level with the 8" shank in the up or down position. In other words, the hitch mounted too low in the "down" position, and too high in the "up" position. The 4" drop solves this problem.
Name:	Andersen 4 inch drop.jpg
ID:	90710   Click image for larger version
Name:	Andersen 8 inch drop compared to 4 inch drop.jpg
Old 10-08-2015, 11:51 PM   #28
AMG
FYI Anderson sells a 2.5" receiver unit too. It isn't listed on their site, but if you desire to go to the 2.5" instead of the 2.0" default, they do sell it.
My F-250 has the 2.5" but I use the sleeve and too lazy/cheap to buy the new 2.5" one. But I thought about it.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
hitch, sway, weight
