01-17-2016, 10:01 PM
#21
Originally Posted by Mahlstedtd
Have had the Anderson Hitch for6 months. No noise, no bucking and light weight. Use it in our 2013 GMC 2500 HD. No need for slider.
Where do you guys buy the safety chains? Would like to install them.
I bought mine through eBay from Trends Auto. They are real Andersen parts.
They've gone up about $8 since I bought mine 18 months ago.
BTW, Andersen spells their name with an E in the last syllable -- Anders En in case you want to do a "Search".
01-17-2016, 10:13 PM
#22
Opps your right. Sorry about that error. I even went to EBAY spelling it that way. I went back to EBay and just noticed the steel is Anderson and the aluminum one is Andersen. Hum good catch, I'll watch closer. It's gotta be a typo for the steel one that I never noticed before.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
01-18-2016, 06:29 AM
#23
I looked at the pullrite to as in option. To possibly wait didn't really care for it. But to each as own not knocking anything.and the pullrite still ways in the 50lbs range if I saw right
2011 RAM 3500 CCLB 6.7L Cummins
2016 Jayco 412W Seismic Wave
01-18-2016, 07:54 AM
#24
John,
I have the Ford Factory Fifth Wheel/gooseneck prep in my truck. Andersen sells two types of hitch. One for the standard rail install, another for using a gooseneck mount. You install your gooseneck ball in the truck, the Andersen attaches to the ball.
Ken
2016 F-250 Super Duty CC LB, 6.2, 4.30
Andersen Aluminum Ultimate 5th Wheel Connection
01-18-2016, 05:26 PM
#25
Yes the Andersen hitch fits any type of gooseneck hitch installed any any type of truck the factory one is perfect
02-04-2016, 09:51 PM
#26
Does anyone know if you have to take the bed liner out? I am going to use the Andersen Al ultimate with my new Sandpiper 360PDEK. TV F350 srw. 6.7
02-05-2016, 04:35 AM
#27
I believe they don't recommend using a plastic bed liner. I have a rubber one that works just fine with it.
02-05-2016, 09:24 AM
#28
The Andersen company is great if you call. They will answer any questions and are very responsive.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
02-05-2016, 09:25 AM
#29
I have a Factory spray in bedliner and have no issues. I would call Andersen Hitch. Before/after I purchased their hitch I called with questions, always got great customer service.
800-635-6106
02-05-2016, 01:15 PM
#30
Blog: RVroadtripper.com
I have the stock GMC rubber bed mat. It's about 3/4" thick and I think it absorbs some road (could be my imagination ;- . Andersen said no problem.
With this post, let me add that I also use a Curt 4" ball extension. The Curt replaces the flip-over ball with one that is mounted to a steel plate and basically moves the ball 4" back toward the tailgate. I wanted more cab clearance but did not want a slider. Why this note is important is because the Curt also raises the ball position.
If you look at the Andersen videos etc., you will note there are two pins in the setup. The top pin holds the ball into the top of the pyramid. The lower pin locks the frame onto your bed ball. Each pin has a cotter latch that keeps the pin from sliding out. Nothing special here, that's the way all pins of this type work.
If you do as I did and choose a Curt extension, then you'll find that the thickness of the Curt means the holes for the lower pin now line up inside the center pyramid tube, basically, you can't slide that std. lower pin in (it's too long). Andersen has a brilliant fix for this. They will send you a shorter pin. You place the tube over the ball, insert the pin, then lower the pyramid down onto the tube. The entire pin holes slide up into the center tube and the cotter clip is no longer needed. You then tighten your top 2 bolts and 1 front bolt and you're good to go.
So....if you plan to use a Curt 4" ball extension, be sure to tell Andersen so they can send you the clip-less pin. It's free. It's easy. It secures the pyramid the same.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
02-06-2016, 10:57 PM
#31
I called Andersen about factory bed liner. It has to go. After everything is install, I think I will cut out square hole in the bed liner to go around hitch and put liner back in.
2011 Ford F350 fx4
Coachman Catalina 303rls
02-08-2016, 09:35 AM
#32
Frog-Toberfest Organizer
I just bought myself a new truck and it came with a pop up brand goose neck hitch. I am looking for a fifth wheel adapter now. I've heard good things about this Andersen hitch. Is it still fairly easy to hook up the camper? I'm still pretty new to hauling fifth wheel and liked how easy it was to back up to the plate on the standard hitch.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
02-08-2016, 10:01 AM
#33
Pretty easy to do. I started out on the Andersen so I can't compare it to the traditional hitch set up. Takes a little finesse to line the ball up but after some practice it is easy. You need to regularly torque down the three bolts on the hitch after hooking up with the ball adapter so there is a little more work to use but very easy to remove from the bed. You also need to check the pin adapter periodically to make sure those bolts are torqued to spec as well. I keep a click style torque wrench in the truck with me. There are definitely trade offs but to me the price was right and it is really smooth to pull with.
02-08-2016, 11:24 AM
#34
02-08-2016, 07:21 PM
#35
Originally Posted by togo444
Pretty easy to do. I started out on the Andersen so I can't compare it to the traditional hitch set up. Takes a little finesse to line the ball up but after some practice it is easy...
You must be mistaken about the ease of use. Everybody who doesn't have one swears it takes a couple three days to hook up if you can get it at all.
...You need to regularly torque down the three bolts on the hitch after hooking up with the ball adapter so there is a little more work to use but very easy to remove from the bed. You also need to check the pin adapter periodically to make sure those bolts are torqued to spec as well. I keep a click style torque wrench in the truck with me. There are definitely trade offs but to me the price was right and it is really smooth to pull with.
I realize there's one(?) bolt that you need to loosen to remove hitch from truck bed, but as far as the others go, can some kind of threadlock be used when first assembled to prevent them loosening up? Might be a question for the Andersen folks(?).
02-08-2016, 07:28 PM
#36
You tighten the three bolts when you install and use the hitch. Takes all of 30 seconds. I check them after use and they stay tight. Connecting is easy, you can see the ball. Usually get it on the first try.
02-12-2016, 06:16 PM
#37
I purchased a torque wrench for only this purpose and haven't had any issue with them loosening up when I torque them to manufacture specs.
I will double check on our next trip this spring. However if I find that they are actually loosening I think the bolts are long enough to add a stop nut on the two front bolts to help lock them in place.
Bob & Cindy
