Old 02-06-2016, 09:57 PM   #31
ccsvolsfan's Avatar
I called Andersen about factory bed liner. It has to go. After everything is install, I think I will cut out square hole in the bed liner to go around hitch and put liner back in.
2011 Ford F350 fx4
Coachman Catalina 303rls
ccsvolsfan is offline   Reply With Quote
Old 02-08-2016, 08:35 AM   #32
I just bought myself a new truck and it came with a pop up brand goose neck hitch. I am looking for a fifth wheel adapter now. I've heard good things about this Andersen hitch. Is it still fairly easy to hook up the camper? I'm still pretty new to hauling fifth wheel and liked how easy it was to back up to the plate on the standard hitch.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 02-08-2016, 09:01 AM   #33
togo444's Avatar
Pretty easy to do. I started out on the Andersen so I can't compare it to the traditional hitch set up. Takes a little finesse to line the ball up but after some practice it is easy. You need to regularly torque down the three bolts on the hitch after hooking up with the ball adapter so there is a little more work to use but very easy to remove from the bed. You also need to check the pin adapter periodically to make sure those bolts are torqued to spec as well. I keep a click style torque wrench in the truck with me. There are definitely trade offs but to me the price was right and it is really smooth to pull with.
togo444 is offline   Reply With Quote
Old 02-08-2016, 10:24 AM   #34
Jack350's Avatar
The Andersen hitch is a great way to tow your rv. At 32 pounds, and quick and easy install and removal it's hard to beat. When you are done just hang on the wall. Tows smooth and easy to hook up. Great hitch solution and has a rear offset of a few inches also.
2012 Crusader 26RLD, 2017 F-350 4X4 6.7.
Hayes Autoformer, Correct track, Maxxis 8008E, Andersen Aluminum hitch.
Jack350 is online now   Reply With Quote
Old 02-08-2016, 06:21 PM   #35
Originally Posted by togo444 View Post
Pretty easy to do. I started out on the Andersen so I can't compare it to the traditional hitch set up. Takes a little finesse to line the ball up but after some practice it is easy...
You must be mistaken about the ease of use. Everybody who doesn't have one swears it takes a couple three days to hook up if you can get it at all.
...You need to regularly torque down the three bolts on the hitch after hooking up with the ball adapter so there is a little more work to use but very easy to remove from the bed. You also need to check the pin adapter periodically to make sure those bolts are torqued to spec as well. I keep a click style torque wrench in the truck with me. There are definitely trade offs but to me the price was right and it is really smooth to pull with.
I realize there's one(?) bolt that you need to loosen to remove hitch from truck bed, but as far as the others go, can some kind of threadlock be used when first assembled to prevent them loosening up? Might be a question for the Andersen folks(?).
dbear is offline   Reply With Quote
Old 02-08-2016, 06:28 PM   #36
Jack350's Avatar
You tighten the three bolts when you install and use the hitch. Takes all of 30 seconds. I check them after use and they stay tight. Connecting is easy, you can see the ball. Usually get it on the first try.
Old 02-12-2016, 05:16 PM   #37
Lvn2tvl's Avatar
I purchased a torque wrench for only this purpose and haven't had any issue with them loosening up when I torque them to manufacture specs.
I will double check on our next trip this spring. However if I find that they are actually loosening I think the bolts are long enough to add a stop nut on the two front bolts to help lock them in place.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
5th wheel, hitch, wheel
