01-16-2016, 10:23 AM
Andersen ultimate 5th wheel hitch
Hey just bought a chapparal 371mbrb and the Reese goosebox is on back order for awhile so I'm going with the Andersen ultimate 5th wheel hitch does anyone have one heard really good things about it and the concept is awesome of it just curious if anyone has one on here
01-16-2016, 10:36 AM
Yes, several of us do and those who have them like them. Do a search for AndersEn Ultimate and then AndersOn Ultimate (since some posters don't use Andersen's official spelling. You'll find several comments.
Just so you'll know, the searches mentioned above will hit on anything Andersen (or Anderson) so you'll have to read through them. You might want to try a search for Ultimate - might yield a shorter list.
01-16-2016, 10:52 AM
They are very good units. I have used it the last two years on my Sierra Sport F37. I have a long bed truck so I don't know how well it works on a short bed unit if you have one. Easy to take out of the bed, just follow the torque protocol on the bolts and it is clean and easy. If you want to spoil yourself get the all aluminum model.
01-17-2016, 07:58 AM
thank you yes i actually have a 2011 dodge flatbed dually and the aluminum one can be used with the recessed ball cant wait to try it out when i bring it home wens. or thurs. i did the research plenty of people do have them and love them. did you guys add the chains on or is it a need be here in ohio it doesnt matter either or just extra safety i guess
01-17-2016, 08:24 AM
I use chains. As you found out, they are required in some states but not in others. However, I've had my trailer in 8-9 states and since I didn't want to have the required/not required discussion with a trooper beside the highway, I paid $63 for them to arrive on my porch. I use them every trip for safety.
Sent (I think)
01-17-2016, 09:09 AM
Okay excellent I agree the safety factor defiantly just going to order them have awhile till are first trip anywhere far so I'll wait till the weather breaks before I put them on
2011 RAM 3500 CCLB 6.7L Cummins
2016 Jayco 412W Seismic Wave
01-17-2016, 09:46 AM
It's an amazing hitch IMHO. I started with a rail mounted Curt slider (16K) that weighed 225lbs. After the in and out process several times I knew I had to find another way since I'm not getting any younger. I did numerous Google and YouTube searches and accidentally found the Ultimate 5th Wheel hitch weighing 32lbs for my answer. I was suspicious at first but not any more. The best part is I can pull a gooseneck trailer then switch to my 5er in less than 5 mins. by myself. Another benefit is I can store it in my 5er storage if I flip the ball over. At 32lbs and rating of 24K GTWR and 4,500 lbs hitch weight I'll never switch back to conventional again. I am however gonna look into purchasing the chains. I wasn't aware of them until this post. So I think if the chains are required then using this hitch doesn't allow pulling a boat behind the 5er just like the gooseneck adapter.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
01-17-2016, 11:19 AM
Excellent I'm glad to hear that I was real skeptical at first when I saw a picture of it with have a flatbed I quite didn't understand the aspect of it even with being around a trucking company my whole life and now watching videos and doing lots of research I'm excited about it defiantly going to look into getting the chains to just to be on the safe side
01-17-2016, 12:30 PM
Blog: RVroadtripper.com
Like Mr. Dan and others, I have the Ultimate and am a recommender. I opted for Curt Cables instead of chains. They curl up and stay out of the way. All I did was add a couple of turn buckles to attach to the bed anchor points. It was difficult finding cables approved for my 10K 5er but they can be found. I also added a clip hook to the safety brake line to make connects easier. Everytime I decide to clear my truck bed when not towing I'm reminded what a great idea it is to have a 32# hitch ;-).
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
01-17-2016, 02:03 PM
I also have been enjoying the aluminum version and love it. I do not know why some spend so much for other hitch systems. Very strong and 32 pounds.
Do you have more info on the cables you are using instead of chains, some pictures. I have been thinking of adding the chains this year and the cables seem like a good idea.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
01-17-2016, 02:19 PM
Here, here, I don't want any hernia for sure. I also have a setup question. What made you decide on curt cables vs factory chains and how did you fasten them to the trailer without the loop bolts Anderson sells with the chains? Are they sold according to weight or one size fits all?
Bob & Cindy
01-17-2016, 02:31 PM
Anderson Ultimate 5th wheel hitch
Pullrite is bringing out their own version of the Anderson hitch. It has a couple of features that that I think are very good. Pictures andl technical information is on their website. Not sure of the pricing as it won't be available until later in January.
I called several rv suppliers and none of them new anything about it.
01-17-2016, 02:47 PM
I looked and agree with you. It's heavier but I do like the guide cup for the hitch ball. Looks like it clips into rails which I don't like, but maybe I'm not looking at picture right.
Bob & Cindy
01-17-2016, 03:09 PM
I also use the Andersen. Very easy to put in/take out of the truck. Another great thing I have found is Andersen's Customer Service. I have called them a few times with questions. They are extremely helpful. If you have any doubts, call them first.
Ken
2016 F-250 Super Duty CC LB, 6.2, 4.30
Andersen Aluminum Ultimate 5th Wheel Connection
01-17-2016, 07:41 PM
Does this hitch fit in a fifth wheel preped 2014 Ford F250? I am currently using a gooseneck adapter and also wonder if this would pull any different.
01-17-2016, 07:42 PM
Yes it will work in your truck.
01-17-2016, 09:20 PM
Probably but you really need to go to their site to answer your question. I'm not sure I know what a 5th wheel prep is for a Ford.
When you say your using a gooseneck adapter I assume you have the ball in the bed of your truck. I have no comparison to pulling a 5er with the adapter. Comparing a Curt 16K E series 5th wheel hitch to Anderson is like changing from a Pinto (hope you know this is a car) to a Cadillac. No more slamming,bucking, or jerking. The Anderson is like your TV and TT are one piece of machinery working together all the time not some of the time.
I know I am biased but the Anderson is a really great design that fills my needs 100%. No I do not represent the company in any way, just in case you want to know.
Bob & Cindy
01-17-2016, 09:45 PM
Have had the Anderson Hitch for6 months. No noise, no bucking and light weight. Use it in our 2013 GMC 2500 HD. No need for slider.
Where do you guys buy the safety chains? Would like to install them.
01-17-2016, 09:52 PM
I found the chain kit on their web site on Amazon and on EBAY Anderson # 3230. Gonna order a set myself.
Bob & Cindy
There is now a new Pullrite ISR Super Lite 20K hitch that is just coming out. Very similar to the Anderson but looks a little better built to me...
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
