Old 05-10-2016, 05:07 PM   #1
Blog: RVroadtripper.com
hbillsmith's Avatar
Andersen Ultimate Aluminum 2016 Model Update
I previously owned the original 2015 Ultimate Aluminum and liked it alot. Back then I did a Youtube video with comments about my installation. I've made some changes in equipment and I now am back to the Andersen Ultimate only this one is the most recent 2016 model that had a few nice changes.
I'm one of those Andersen fans that installed the kingpin adapter backward to change the pivot point to better match my mor/Ryde pinbox. Texas weather these last few weeks has kept me off the road, so I decided to do an updated Youtube video. As with the first one, this video was unsolicited and uncompensated, I just did it for fun and in case it may answer anyone questions. Also, I admit to posting this exact same message on RV.net.
Here's the link:My amateur Andersen Ultimate 2016 Update Video
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 09-01-2016, 08:50 AM   #2
lesptr's Avatar
I ordered the Anderson last night. This video was a big help. Thank you.
Sent from my iPad using Tapatalk
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 09-01-2016, 09:32 AM   #3
hbillsmith's Avatar
Originally Posted by lesptr View Post
I ordered the Anderson last night. This video was a big help. Thank you. Sent from my iPad using Tapatalk
Great. If you are installing over a bed mat and particularly if you are also using a Curt Extender ball, because this changes the bed ball height, you need to let Andersen know that you require a sheared pin and a shortened inner square tube. If you didn't order direct from Andersen, I believe they will do a cross ship swap.
Also, if you are new to 5th wheel towing, be careful to close your tailgate after you drop on to the hitch but most importantly BEFORE you pull out. An open tailgate's corner can hit your trailer as you make that right turn out of your camping spot. So just hookup and CLOSE THE TAILGATE!!
Old 09-02-2016, 06:25 AM   #4
lesptr's Avatar
According to Jason, should not need the the extender with the block positioned the way you did yours. We'll see. This will be my first experience with a fifth wheel and I admit I'm a bit nervous. If it's ok, I might be asking questions as we go.
Thanks for all your help.
Les
2015 F350 6.7
Old 09-02-2016, 07:48 AM   #5
DDC
DDC's Avatar
Very good video, your detailed explanations will be a great help to anyone contemplating this hitch which is becoming very popular, I'll give you a 10.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 10-14-2016, 01:35 PM   #6
florabama's Avatar
Instead of starting a new Andersen Ultimate thread I'll ask my question here.
Anyone using the Andersen Ultimate with the TrailAir Air Ride pin box? And if so, how is the clearance with bed rails and tailgate?
And finally, is the Air Ride an overkill with the Andersen? I have ordered the Air Ride on a Cedar Creek 34RL2 but if it isn't need to reduce chucking I may drop that option.
And BTW, RAM factory gooseneck prep package doesn't not allow the 4" offset ball that seems to be a popular configuration.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
Nights Camped: 2017=61
Nights Camped: 2018=25
Nights Camped: 2019=12 | Booked=6
florabama is offline   Reply With Quote
Old 10-14-2016, 02:45 PM   #7
hbillsmith's Avatar
florabama you can call Andersen customer service and they will advise you on their experience with others that are using the TrailAir Air Ride. In my case, one of my issues was trying to get my Wildcat to tow level given how high the bed is on my 2015 GMC 2500HD 4x4. With the Andersen at the lowest ball height, my trailer sits about 1" to 2" nose high and that is acceptable. To add the TrailAir (I spoke with them) would raise the nose about another 3" from my current config so I passed. I did find that the 5th Airborne because its shock and airbag are internal (TrailAir is external) would not raise my nose. I do think the TrailAir design has advantages over the 5th Airborne but the downside is that additional height for me. In the end, I just never got around to adding either one. I can get some chucking on really bad roads but I'd say 90% of the time my ride is fine as is.
Old 10-14-2016, 03:09 PM   #8
florabama's Avatar
Originally Posted by hbillsmith View Post
florabama you can call Andersen customer service and they will advise you on their experience with others that are using the TrailAir Air Ride. ... To add the TrailAir (I spoke with them) would raise the nose about another 3" from my current config so I passed. I did find that the 5th Airborne because its shock and airbag are internal (TrailAir is external) would not raise my nose.
Excellent input, thank you. I did speak with two reps from Andersen and today Jason said the Trailair would be okay but I don't think he understood the specific model, therefore he didn't mention raising the nose height (3 inches).
So I just contacted my dealer and requested the Air Ride pin box option be removed from my order. Like yourself, if I see excessive chucking or movement after I get to towing I'll consider the 5th Airborne or a Moreride pin box.
And BTW, I have watched your video more than once and appreciate all the detail you included.
Old 10-19-2016, 09:00 AM   #9
Nice video...thanks for posting...I really like my UAH...easy to hook up and no noise while towing although when hooking up...the ball has to be pretty much deadon...
Cedar Creek 38FB Ram 3500 Dually
bobsue1 is offline   Reply With Quote
Old 10-19-2016, 12:28 PM   #10
hbillsmith's Avatar
bobsue1 Andersen has an adapter so you no longer have to have "the ball..pretty much dead on"
You can call or email Andersen customer service (Jason is the one that usually takes these inquiries) and ask about adding their new Funnel Adapter. For awhile they were offering the Funnel either free or heavily discounted to existing Andersen Ultimate users. I have it and boy does it make hookup easier. Highly recommended.
The Funnel is an upside-down dish shaped bowl that mounts onto the pinbox adapter you already have. With the funnel, when you backup to load your trailer all you need to do is be within about 3 inches of the hole. As the trailer drops down onto the ball it is captured by the bowl and slides into the hole.
Andersen posted this youtube of the adapter in action about 6 months ago. Here's the link Andersen Funnel In Action
modifications
