Old 12-10-2014, 06:57 PM   #11
thestrangebrew's Avatar
I've got the AWDH and running with the TT in my sig. Does a great job with sway, but I agree it didn't do much for putting weight back to my front axle. I've got a relatively light trailer though so it's not too bad.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s
thestrangebrew is offline   Reply With Quote
Old 12-10-2014, 08:14 PM   #12
Stormrider151's Avatar
I just got the straight line and am trying to get 100% return to the front with no luck (so far). I guess I'll stay away from the Anderson if that's a problem witt them. Thanks for the info.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 02-08-2015, 05:50 PM   #13
Hi I hope this post is not to old. I bought a new 2012 V- Lite 30WRLS in 2013 at the time I had a 97 F250 super cab 8ft. bed 4X4 Diesel. I had the dealer install a Fastway E2 hitch. I towed the trailer without any problems. in 2014 I bought a 08 F250 super cab 8ft. bed 4X4 Diesel. The trailer does not seem to be as stable as it was with the 97. I took it back to the dealer to see if the hitch needed to be readjusted because the o8 is higher than the 97 was. They seems to think everything was ok. I still do not feel that it is right. I also get a little motion at about 62 miles an hour. What I'm after is do you folks think the Anderson hitch would be better? I know it would be better for connecting and unconnecting. It is a pain jacking the trailer up after you have the hitch connected to put the bars on.
welder1 is offline   Reply With Quote
Old 02-09-2015, 12:58 AM   #14
Sounds like you need to go through the setup and check everything out. You are correct with the taller truck can make a big difference on how much weight is transferred to the front axle
firedaniel is offline   Reply With Quote
Old 02-18-2015, 01:07 AM   #15
Blog: RVroadtripper.com
hbillsmith's Avatar
Just bought the Andersen Ultimate All Aluminum version. Love it. Check out youtube vids.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 02-23-2015, 12:24 AM   #16
northstar1960's Avatar
Originally Posted by Stormrider151 View Post
Ok, thanks. My bad I should have done that first.
I have not seen any andersen hitch discussions that are that are less then 2 yrs old . I just ordered one for my new xlr 29hsf that i will be towing with a chevy 2500 hd 6.0 . i expecting good results as most that complained about the andersen never used it or had to small a TV for the TT they had
northstar1960 is offline   Reply With Quote
hitch
